Go to Post Man, I never thought I'd have to cite a rule during the offseason. - Karibou [more]
Unread 06-02-2002, 17:02
nwagers nwagers is offline
#0240 (Mach Vee)
nwagers is an unknown quantity at this point
Send a message via AIM to nwagers Send a message via Yahoo to nwagers
mounting electronics
I could find the rules on this one. Are we allowed to mount the electronics using heavy duty velcro?
Unread 06-02-2002, 17:03
#0240 (Mach Vee)
typo
I meant I "couldn't" find the rules. lol
Unread 06-02-2002, 17:14
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
I don't think there are any restrictions oh how you mount them. Personaly, I wouldn't exactly use velcro....
~Adam
Unread 06-02-2002, 21:17
Pamela's Avatar
Pamela Pamela is offline
Half the JVN,All theTaste
Pamela has a spectacular aura aboutPamela has a spectacular aura aboutPamela has a spectacular aura about
Send a message via AIM to Pamela
I'm pretty sure you can use velcro but it woudl not be recommended because every time your robot got banged it woudl rip the velcro apart, eventually causing your electronics to fall off....
~Pamela, Alumni of 166 and 229
Unread 06-02-2002, 23:19
Jeremy Davis Jeremy Davis is offline
#0422 (Mech Techs)
Jeremy Davis is an unknown quantity at this point
Send a message via AIM to Jeremy Davis
Velcro will work!
Actually, we used velcro quite extensively last year, and I know that while there wasn't much hitting going on last year, we found velcro (the stuff that came in the kit) to be extremely strong and reliable. I would say go for it for the electronics.
-Jeremy Davis
Unread 07-02-2002, 11:40
Keithicus Keithicus is offline
#0920 (Lancers)
Keithicus is an unknown quantity at this point
Same here, I've been doing this for 5 years and every year velcro has done the job. Gaurunteed its not the nicest solution but I've never had any of the electronics fall off.
Dont knock it til you rock it.
Unread 07-02-2002, 13:15
CaptainPlaid's Avatar
CaptainPlaid CaptainPlaid is offline
#0314 (Megatron Oracles "Big MO")
CaptainPlaid is an unknown quantity at this point
Gotta get the good stuff
We have used INDUSTRIAL VELCRO from Radio Shack for the last two years on Big MO to mount Victors, Spikes, and even the Robot Controller. In fact, I used less of it this year because I could hardly remove the RC last year.
It is much easier than bolting and you can make it look very clean if you take your time.
I have not failed. I have just found 10,000 ways that won't work.
Thomas Edison
Unread 07-02-2002, 14:19
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Re: Gotta get the good stuff
What sort of surfaces did you stick the velcro to? We are thinking of making our controls boxes out of 1/8" Luan plywood to save weight....and I wonder if the Velcro would stick to it well enough. (I can see how it would strick to Lexan as it is smooth...but lexan is 2x the weight of Luan)
Also...how does the velcro compare weight wise to the bolts/hardware needed to mount the electronics?
-Quentin
PS: Just wondering....From the above....would you ever guess that we are currently having a weight problem?
Team 4987: Megarams
Unread 07-02-2002, 15:00
Response
We have mounted to aluminum in the past but I assume all surfaces would be pretty much the same. I don't have the package right here but it is very tacky. (It even comes with an alcohol pad to wipe off the surface to ensure maximum adhesion.) Just make sure you get Industrial. The packaging is different and you can also get it at Home Depot.
Well.........it only takes a 1" square of velcro to mount a Victor. That weight would be significantly less than 4 bolts and nuts or even 2 bolts and nuts.
We all know about that weight problem.
Thomas Edison
Unread 07-02-2002, 21:28
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
McMaster to the Rescue...
We have used the "Self-Lock Mushroom-Head Super-Adhesive-Backed Strips" from McMaster for a number of years and it works wonders.
A little dab will do ya!
If you want to get the adhesive off, you can use the standard version.
The catalog page is 3163. Go to McMaster.com and type "3163" in the search field.
One nice thing about the self lock feature is that you only have to stock one item -- it sticks to itself so you don't have to stock both hooks and loops.
Check it out.
Joe J.
McMaster.com
Unread 15-02-2002, 13:09
dets002's Avatar
dets002 dets002 is offline
#0811 (Cardinals)
dets002 is an unknown quantity at this point
Send a message via AIM to dets002
We have our controls on .185 inch lexan, mounted with wire ties; it saves some weight over using screws/bolts.
Fischer Price mounting screw ateene Motors 1 09-02-2003 21:00
drill motor mounting whynot Technical Discussion 3 03-02-2003 08:24
Sideways mounting srjjs Electrical 13 25-01-2003 20:31
custom electronics Rickertsen2 Electrical 1 13-01-2003 00:15
new bosch pinion and mounting ajlapp Motors 1 08-01-2003 17:16
