Go to Post this is ridiculous, a complete waste of time, and probably not particularly effective. I love it! - The other Gabe [more]
Unread 04-10-2003, 18:40
slackware180 slackware180 is offline
#0180 (SPAM)
slackware180 is an unknown quantity at this point
Linux network
Does anyone know how to setup a network under vector-linux using a usb Wi-Fi modem what should i set for hostname gateway and the other stuff.
Unread 04-10-2003, 18:57
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
I don't know anything about setting up the interface, itself. You'll probably have to find a kernel module for the device, itself. USB support being necessary is a no-brainer. I've never used Vector Linux, though.
Other than installation type stuff, the hostname of the computer is just any name you want to give it (For instance, I like to name my computers after Aphex Twin songs. So far, I have Phloam, Quoth, Ziggomatic, Ventolin, and Nannou.), the gateway (set using the `route` command) should be set to the gateway that your ISP has assigned to you. The same goes for the subnet mask and the broadcast address, both of which are set using the `ifconfig` command. Typically in Linux, to define DNS servers, there's a file named /etc/resolv.conf, in which you'd have an individual line for every DNS you're using, with the format being "nameserver DNS_IP".
Hmm. I hope this helps, some.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Linux SteveC116 3D Animation and Competition 22 25-03-2004 15:07
Linux And Windows XP Raven_Writer Chit-Chat 4 06-08-2003 18:53
RoboEmu for Linux (PBASIC emulator) rbayer Programming 5 21-11-2002 21:08
Linux file extensions rbayer CD Forum Support 5 14-11-2002 23:04
MS Linux D.J. Fluck Chit-Chat 5 21-05-2002 17:47
