Go to Post A solution will present itself, all you have to do is be ready to take advantage of it when it does. - James1902 [more]
Unread 07-02-2002, 18:51
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
Our team's light also doesn't rotate all the time, and we definately think its a quality issue thing. Sometimes it just stops, as if jammed. Usually if you give it a small push it goes, other times you have to manually spin it. We're thinking about taking it apart and finding the sheizerness in it ourselves.
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 08-02-2002, 20:19
Two things to look for...
First, always check that the hardware inside the light is tight because any wires that are under hardware conduct power to the light and motor. Since the light is intended for use on automobiles the body of the light is one side of the power supply. The mounting hardware is designed to conduct and needs to be tight to make that happen. (The lamp "on" is only relative...how bright is bright?)
Second, check the connections on the Spike. If you haven't measured the current to the light you will be surprised that it is a lot higher than you think.
Unread 08-02-2002, 20:36
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Exclamation I don't know whats the matter!
Ours works just fine. We just got it 3 days ago! ***finally***
I bet one of the students took the lens off and started twirling the reflector in there lol.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Please...no more steenkin' light! Andrew General Forum 37 17-04-2003 23:06
Lights on our robot (in addition to the rotating light)... archiver 2001 1 24-06-2002 01:02
rotating light archiver 2000 1 23-06-2002 23:06
Important info about light Jay Lundy Technical Discussion 10 12-04-2002 11:37
Please help me with the size of the rotating light!!! bigqueue Technical Discussion 5 21-01-2002 09:40
