Go to Post Between reading the Manual, Q&A, Team Updates, the Blog, and Chief Delphi, you can be one of the most valuable members of any team. - Gregor [more]
Unread 05-10-2003, 15:14
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Originally posted by KenWittlief
this is a common misconception. You can get exactly the same set of input signals from either setup
Well, there are a few differences. Yes, you can get the same signals, but some types of signals are harder to achieve with one stick. The biggest one that comes to mind is driving the left stick all the way, and the right stick none or slightly forward, for a bigger arc. You can do it with one stick, but it's harder to control the amount of arc, because most people don't understand the 1-stick code fully.
Jeff Waegelin
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
one stick drive Hendrix Programming 3 14-02-2003 20:53
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
