pic: LEGO Vernier Gearbox
All rite! 3 speed, Nice Job Man
i Hope im the Inspiration to this Ive built 3-speed before but I had problems with getting the Rcx to stop on the gears, mabie i should try again with my new rotation sensor |
Why do you need a shifter for lego league? You don't need to push and load or any other robot, so high gear will work fine. It is not worth the motor or whatever actuator you are using to shift, as you could use it for an arm or something.
What is shift-on-the-fly about it? The fact that the gears will mesh because they are plastic? It actually wouldn't shift unless the robot is moving. If you are just building this for the heck of building building it, then thats awsome, and you should ignore this rant. |
Kevin: Nobody ever said it was for Lego League.
Lego's are a kids toy with so much potential for adults to use. There are designs that can be made and used with Lego's that can't be used well in real life, or real life things that can be converted into Lego things. Such as this picture. None of us (I assume) have seen this design, done with lego's until now. That's what makes it so cool. Something new and interesting, being made from a toy. |
Lies I say! Wetzel |
It's not for the LEGO competition; I just built it out of LEGO cause it's a lot easier than using real metal and stuff.
#7
I don't want to start anything here, its just that Im doing Lego League twice a week, and thats where my mind is at with legos. That is truly an awsome design. I have made something very similar to that myself. Now I will challenge you: Using two gearboxes very similar to that, make a swerve/crab drive 3 speed lego robot. I had one mechanically made, but not programmed. edit: I have known how to drive a stick since I was 14. I have done alot of work with cars, legos and anything mechanical. Just because I don't put up pictures of everything I do, doesn't mean I didn't do it. I am sorry to "shoot down" any ideas. Last edited by Kevin A : 10-10-2003 at 23:59. |
#10
I just orderd the turntables Its going to be a reality soon
| pic: Gerrish Gearbox MK-III #2 | CD47-Bot | Extra Discussion | 26 | 12-09-2003 11:35 |
| pic: Gerrish Gearbox MK-III | CD47-Bot | Extra Discussion | 22 | 04-09-2003 16:32 |
| pic: 3-speed lego geerbox | CD47-Bot | Extra Discussion | 4 | 14-07-2003 23:42 |
| Shift on the fly LEGO gearbox | rlowerr_1 | Robot Showcase | 17 | 14-07-2003 23:33 |
| pic: Gerrish Gearbox MKII | CD47-Bot | Extra Discussion | 63 | 03-07-2003 00:06 |
