Go to Post Sorry, during my fluid mechanics lectures on drag I must have been designing a gearbox in my mind. FRC season will do that. - sanddrag [more]
Unread 06-10-2003, 13:46
caffel caffel is offline
AKA: Charlie Affel
FRC #0423
caffel is an unknown quantity at this point
2004 edu controller (PIC) is out!
Its on the Innvation FIRST Site now.
I've atached a snagit image of the unit.
Name:	2004 edubot controller.gif
Charlie Affel,
Mentor 423
Unread 07-10-2003, 14:00
Skabana159's Avatar
Skabana159 Skabana159 is offline
Robotics and Field Hockey
AKA: Jesse C. Owens
#0159 (Alpine Robotics)
Skabana159 is on a distinguished road
Send a message via AIM to Skabana159
Pretty sweet! What are the screws(?) on the top right hand corner?
/*EDIT Oops they are solenoid outputs duh EDIT*/
"What most people do not understand is that the Buddha, the Godhead, resides just as comfortably in gears and circuits as in hills and trees. To believe otherwise is to dilute the Godhead."
-Robert Pirsig, Zen and the Art of Motorcycle Maintenance
Unread 09-10-2003, 10:51
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
2 questions.
1. How much does it weigh?
2. How many lightening holes will it take?
Wetzel
3. Are there refill paks for the magic smoke?
Unread 09-10-2003, 11:06
solonoids? Either my memory is really going, or this is something new? a new type of actuator?
We let the smoke out of our OI power supply adapter the first day we used it (unplugged it from the OI and the connector landed on a piece of metal)
once that magic smoke leaks out, its really hard to pump it back in - easier to just buy a new one.
Unread 09-10-2003, 12:15
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
I believe the Solenoid output only appears on the Edubot, not the competition robot controller.
Matt
Unread 09-10-2003, 13:13
AKA: Charlie Affel
FRC #0423
solenoid
I believe that solenoid means a relay, like the spike.
Charlie Affel,
Mentor 423
Unread 09-10-2003, 14:44
but the relay spikes have a 3 wire control, like the victors
those screws labled 'solonoid' are single screws, 1 per
maybe I'll bebop over the the Innovation First site and see if the docs are up for the new EDU kit yet.
Unread 09-10-2003, 14:55
nothing really clear on the INF site - looks like either there are 6 relay spikes built into the new edu RC (so you can hook up external motors directly to it)
or they have some type of electro-magnetic solonoid planned for future release - something like a minrature pneumatic cylinder that uses magnetic force instead of compressed air?
guess well have to wait and see.
Unread 09-10-2003, 14:59
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
The spikes have three wire but they work like a solenoid.
Two wires, white and red, are +5v and the black is ground. The white and red would have to be split and plugged into individual solenoid out locations on the EduRC.
I think that the extra screw locations on the solenoid bank would be for ground. IFI sells a solid state relay that would work off this set-up. We use the same SSR manufactured by CRYDOM here at work.
Unread 09-10-2003, 15:21
but there is no 'relay out' set of 3pin connectors on the RC photo above,(like there is on the competition RC) - only PWMs and those mysterious solonoid out connections.
Unread 09-10-2003, 18:44
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Yes there are.
In the lower set, there's a section labeled "Digital In/Out - Analog In". Seems to me that digital out would be equivalent to relay outputs. Keep in mind that IFI also makes the Spike relays that we use. Maybe they've changed the interface in those, as well (instead of being whatever it used to be, it could be just a TTL digital signal, now).
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 09-10-2003, 19:06
so then what are the Solonoid screws for?
if they were ground, wouldnt it say GROUND RETURN, instead of having numbered Solonoid Out screw terminals?
Unread 09-10-2003, 19:31
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
This is only speculation, but I think they added the solenoid outputs to prevent you from needing spikes with the EDUbot.
There are eight screws, but the RC only has 6 solenoid outputs. The extra two screws are labeled with a +, so maybe the solenoid output states are open and grounded. It would be a nice feature to not need the extra spike hardware on a prototype.
Unread 09-10-2003, 23:02
Umm Errr...
I think they are meant so you cna connect whatever you want. IE(a relay). They are prolly just high current 5 or 12v outs. From the picture it looks like there are six ground returns, and 2 common positives, and they are using low side control.
1139 Alumni
2004 Robot Controller CNCBoy461 Electrical 18 02-12-2003 16:36
power connector for 2004 EDU controller kc8nod Robotics Education and Curriculum 6 25-11-2003 16:59
pic: The Full 2004 RC?! CD47-Bot Extra Discussion 7 07-10-2003 17:19
pic: 2004 Game Revealed! CD47-Bot Extra Discussion 28 12-09-2003 12:08
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
