Go to Post I began to see myself as an independent person who was not only being inspired, but able to inspire others and strengthen the FIRST program as a whole. - Jaine Perotti [more]
  #31   Spotlight this post!
Unread 08-10-2003, 19:41
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Originally posted by Mike Soukup
Bill passing Wildstang pictures & videos to John & the rest of FIRST....hmm....that sounds oddly familiar
Mike,
I'm sure I don't know what you're talking about, and... they were all beautiful and inspiring.
John
  #32   Spotlight this post!
Unread 08-10-2003, 20:24
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
thanks Mike!
im wondering why you say you didnt need a lot of traction in the 2002 game?! that was the one with the 180 lb goals that had to be dragged into your zone to score
to answer a question.......
we designed specifically to pick up balls and not manipulate the goals, we didn't win, but i'm not entirely sure it was because we ignored the goals.
ajlapp: I'm still amazed at how cool your Kiwi drive is and also how simple & elegant the control system was. Great job with that bot.
thanks mike, by the way, i've got chris ankeny here diligently replicating the StangPS for me! hope you don't mind.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
  #33   Spotlight this post!
Unread 08-10-2003, 21:20
JVN JVN is offline
@JohnVNeun
Re: i posted this earlier
Originally posted by ajlapp
the first and last FIRST Killough, for now
http://stuweb.ee.mtu.edu/~alkrajew/FIRST/kiwi.mpg
Anthony,
Just so you know, we on 229 LOVE that video.
We show it at demos sometimes.
The kiwi-drive itself is wicked cool.
Hopefully we can emulate a quick one at some point. We also loved your *programing* method.
John
  #34   Spotlight this post!
Unread 08-10-2003, 22:09
AKA: Anthony Lapp
thanks again
thanks again for the compliments.........
we made a quick kiwi out of the edu robot just for demos, worked pretty good, and believe it or not our programming worked without any modification.
speaking of modification, my programming guys are sweating bullets about having to re-write their kiwi code for the new controllers.
Anthony Lapp
RobotOpen
  #35   Spotlight this post!
Unread 08-10-2003, 22:12
can you give a breif explaination of how the joystick inputs are used to control the 3 motors at 120° angles from each other?
its not clear from the video exactly how the bot was intended to be driven - lots of spinning and twirling going on there.
  #36   Spotlight this post!
Unread 08-10-2003, 22:51
AKA: Anthony Lapp
trade secrets
i'd love to explain.........what i can anyway.
we used three normal joysticks, connected together with a "y"-shaped yoke, and ball joints. the x-axis of each stick was unwired, and the threey-axis of each stick were wired into one coupler.......just to save space on a cramped IO.
so each y-axis of the joystick represents the velocity vector of one wheel. the joystick does the complex task of converting cartesian coordinates to polar coordinats inherently.
the robot goes in the direction the stick is pushed, or spins if the stick is rotated in the center.
the attached pictures show how the joystick is a vector based model of the real robot......instead of a motor and gear set, you have a potentiometer. you manually input the velocity of each motor and the robot responds. (both pictures were prototypes)
problems!
our drivers created what they called slip. this was their method for driving. it was based on a general direction rather than a finite point in space. they kind of glided the robot to its position. the joystick doesn't make it super easy to go in straight lines, but straight is irrelevant when you can go anywhere instantly.
we worked around this by making multiple faces for our robot to operate on......front didn't really matter.
Anthony Lapp
RobotOpen
  #37   Spotlight this post!
Unread 08-10-2003, 22:58
thanks for the info.
simply awesome!
  #38   Spotlight this post!
Unread 09-10-2003, 03:57
Bill Gold Bill Gold is offline
Retired -- 2006
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
Originally posted by Joe Ross
I certainly wouldn't discourage 702 from working on a swerve drive, whether or not they design their robot around it. They have the added bonus that they would be only the 2nd team to have a working swerve on the west coast (258 being the first).
Actually, team #360 from Seattle, WA (my former physics teacher's current team) had a double shaft swerve in the 2002 competition. Also, team #998 from Alaska had a double shaft swerve this past season (2003).
At least I told you before more than 8 IPs downloaded the pics/vids. Don't I get any credit for that? By the way, it wasn't me who passed the url to John. There was in intermediary .
Here are a couple of pictures from 111's 2002 Inventor Award submission.
http://www.seadawgs.com/111/eng.jpg (two engineering drawings)
http://www.seadawgs.com/111/DSCN0736.jpg
Here are a few pictures of 258's 2003 drivetrain.
http://www.seadawgs.com/258/cimgearbox.jpg
http://www.seadawgs.com/258/cimassembled.jpg
http://www.seadawgs.com/258/cimassembled2.jpg
http://www.seadawgs.com/258/cimassembled3.jpg
http://www.seadawgs.com/258/cimassembled4.jpg
http://www.seadawgs.com/258/cimassembled5.jpg
http://www.seadawgs.com/258/drillgearbox.jpg
http://www.seadawgs.com/258/drillmounted.jpg
I've got drawings for all of 258's drivetrain components if anyone's interested, as well.
<edit>
I forgot to mention that I'm working on a paper describing the entire design process that led to 258's swerve drive this year. My goal is to use this in the WRRF's Motors/Drivetrain class in November and December.
</edit>
  #39   Spotlight this post!
Unread 09-10-2003, 05:08
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Also, team 159, Alpine Robotics from Fort Collins, Colorado, for all intents and purposes, had as much of a swerve system as we did (I consider them far enough west to be "west"). It's too bad, though, that they had some technical difficulties at the Silicon Valley Regional, in 2003, and were forced to lock two of their gearboxes, and install casters, if I recall correctly.
Team 668 had the preliminary workings of a swerve system, as well, but again, due to technical difficulties, it wasn't functional for competition.
Credit where credit is due...
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
  #40   Spotlight this post!
Unread 09-10-2003, 10:22
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
its all because were all too lazy to turn our bodies in the rite directioin
  #41   Spotlight this post!
Unread 09-10-2003, 10:33
JVN JVN is offline
@JohnVNeun
<edit>
</edit>
Bill,
We're thinking about a swerve for 2005 (when Eric and I are in Senior Integrated Design class, and get to do FIRST for a grade). So I'm already gathering ideas/concepts. I'd love any information you'd share, and would be VERY interested in you're paper.
(brief aside: I'm working on a similar paper for some of the technology we're currently developing.)
I like to think of your swerve drive as "the working man's swerve". Unless I'm missing something, it seems like one of the *easiest* to fabricate. 229 has CNC manufacturing, but nothing really above that.
John
  #42   Spotlight this post!
Unread 09-10-2003, 11:22
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Hmm, that's a really cool design!
Mine does not have the motors on the wheel assemblies, however, and it uses more chain than gears...
I'll let you know how it turns out...all the prototypes so far have worked...
I'm not really sure who has had a crab/swerve drive here on the east coast...
I'm pretty sure there was 1 I remember from this past year...maybe we'll be the second?!
Heh...
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
  #43   Spotlight this post!
Unread 09-10-2003, 12:16
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Go 702 !!!!!!!!!! lol lil team pride
But anyways thanks for alot of the help you guys have lead me into odd and weird directions with this thing.. ill try wiht one of the mentors to build a prototype from a pre existing frame except were not trying a crab drive despite the obivious love affair you all have with it.. 702 going with a omni drive using all omni wheels in standard omni setup tho i do realize the obvious set back of less traction its alot simpler to build for now and the teams a lil weary on difficult new desings so they needed to be wowed right now with omni drive maybe well head in the crab direction later
does anyone one know where to get already made omni wheels.. i found a few places but does anyone one have somethign they already know is good?
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
  #44   Spotlight this post!
Unread 09-10-2003, 12:22
Matt Reiland's Avatar
'The' drive behind the drive
There may be better pictures around our gallery, and I'm pretty sure Matt Reiland has some good closeups too.
Hmmm how about this......
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
  #45   Spotlight this post!
Unread 09-10-2003, 12:24
SpaceOsc's Avatar
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
Talking Omni Mania
Greatly appreciated
But i shoulda made it clearer I WANNA BUY WHEELS!!!!!!
lol thanks for the the pic tho ::drools ::
Post your omni wheeled robot pics CyberWolf_22 Technical Discussion 24 02-12-2004 20:25
How fast is fast to get on the hill? ianbbat General Forum 76 09-03-2003 21:05
Omni Wheels! jrgrim12 Technical Discussion 5 04-02-2003 16:07
Omni Directional Wheels Will Seymour General Forum 3 11-01-2003 12:43
We need Omni Wheels!! archiver 2001 0 24-06-2002 01:02
