Go to Post Mistakes happen. It's how we react to them and what we learn from them that shows what type of people we are. - Daniel_LaFleur [more]
Unread 10-10-2003, 09:51
Tton Tton is offline
#1089 (Team Mercury)
Tton is on a distinguished road
Send a message via AIM to Tton Send a message via Yahoo to Tton
Can I get an example of?
I want to see a simple code in C so i can look how it all is. This year im learning C++ and wanted to see what it looks like!
T-ton
Unread 10-10-2003, 10:30
Here's a very simple program that counts input lines.
Main()    /*count input lines*/
	int c, nl;
	nl=0;
	while ((c = getchar()) != EOF)
		if (( c == ‘\n’)
			++nl;
	printf(“%d\n”, nl);
Unread 10-10-2003, 10:32
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
#include <stdio.h>
main()
for(;
printf ("Hello World!\n");
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 10-10-2003, 11:06
hobbes hobbes is offline
hobbes is an unknown quantity at this point
you'll find that C looks very similar to C++ (as it should, it is the next rev of C, hence the "C++"), although you will not be able to use some common C++ functions like "cin >>" and "cout<<".
Unread 10-10-2003, 11:19
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Saying that C++ is the next revision of C is a bit misleading. C++ is C with object-oriented extensions (as well as a few others). C is not being replaced by C++. There are many uses where C is much more appropriate to C++.
Matt
Unread 10-10-2003, 13:01
your right matt, rev was a bad choice of words.
Unread 10-10-2003, 22:27
djcapelis's Avatar
djcapelis djcapelis is offline
Fried Manic Custard
None #0675 (Geeks with Power Tools)
djcapelis will become famous soon enoughdjcapelis will become famous soon enough
Send a message via ICQ to djcapelis Send a message via AIM to djcapelis Send a message via Yahoo to djcapelis
I would argue otherwise, there are no places that c++ cannot do just as well as c, seeing as it's almost completely backwards compatable... just because the new features are there, doesn't mean you've got to use them.
"I have more friends than enemies, I'm working to resolve the issue."
Unread 11-10-2003, 08:55
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Originally posted by monsieurcoffee
#include <stdio.h>
main()
for(;;)
I've not done console-C in a while, but I do believe it is actually:
#include <stdio.h>
int main(int argc, char *argv[])
   for(;;)
        printf("Hello World!\n");
   return 0;
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 11-10-2003, 09:54
Electrical Engineer
Rookie Year: 1995
Both codes will work...
Raven_Writer's code requires two passed parameters at invocation... argc (an integer) and argv(a pointer to an array of characters (also known as a string)). However, neither is used by the function "main".
monsieurcoffee's code is more traditional and correct as a stand alone program. However, he needs to indent his code so that it is more readable... Without indenting, any non-trivial code is very hard to maintain.
Both Matt and djcapelis are correct but (IMHO) Matt's mindset is more correct for this project... C is a subset of C++, however, using C++ for the PIC processor (if you could) would be like hanging a picture with a sledgehammer. It can be done if you are very careful but, chances are, you will hit your thumb a few times quite unnecessarily.
Code for the robot should be simple and elegant with static variable structures. There is absolutely no need for C++ and all the excess baggage it brings with it.
Mike Betts
As easy as 355/113...
Unread 11-10-2003, 10:19
AKA: Eric Hansen
monsieurcoffee's code is more traditional and correct as a stand alone program. However, he needs to indent his code so that it is more readable... Without indenting, any non-trivial code is very hard to maintain....
Not to be nit-picky about this, but if you compiled monsieur's code, it wouldn't work because 1, main is not actually declared, and 2 main doesn't return a value (but that's only if you declare main to be an integer, and not void).
Y!: synsoflife
Unread 11-10-2003, 10:30
It only really becomes an issue when you're working with embedded controllers. C++ requires quite a bit more overhead than C does (well, many features of C++ do). This overhead is a very bad thing in a limited environment such as an embedded control. The other issue with C++ is portability. There are many more compliant C compilers out there than there are C++ compilers. These C compilers also run on many more different systems than C++ compilers. I will admit this is becoming a thing of the past but it's still something to consider.
Matt
Unread 11-10-2003, 12:54
Electrical Engineer
Rookie Year: 1995
Eric,
I did compile and run Matt's code under Turbo C and Quick C with no problems. His program is the simplest code which is guaranteed to run under ANSI compliant C.
see http://www.lysator.liu.se/c/simple-c
Now to correct an error I made...
Your example is valid under DOS, etc... In your code argc is a integer which is the number of command line parameters and argv is a pointer to an array of pointers to arrays of characters. These strings are the command line parameters entered by you when you run the executable.
see: http://www.lysator.liu.se/c/multiple-level
Without adding this, Matt is unable to access command line parameters which is OK because we will not be running under DOS anyway...
As I said... Your code also works... I did not mean to start a fight here.
Peace.
Mike Betts
Unread 11-10-2003, 12:57
AKA: Eric Hansen
Eric,
Peace.
Sorry
I'm still stuck on PC-coding, and forgot about the point, which was to discuss the new language's syntax.
You didn't start a fight, it was me that forgot for about 3 hrs. what this was actually about
Y!: synsoflife
Unread 11-10-2003, 14:11
djcapelis's Avatar
Fried Manic Custard
Eric,
<snip>
Not exactly accurate, first, to comply with ANSI C Raven_Writer is correct in saying that main must return a value as ANSI C specifically says main must be declared as int.
As for command line parameters, they aren't just for DOS... if so they'd be useless... that command line sucks. They are also the same to access command line parameters on UNIX type operating systems. (Which if these Micro controllers were running BrickOS we theorectically might care about, but then again, they aren't.)
Unread 11-10-2003, 22:21
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
As posted in the Programming Help thread, this site provides many examples of C programming: http://computer.howstuffworks.com/c.htm
There are more examples and explanation there than we could possibly post.
--Damian Manda
