Go to Post Yes, blame Gary. For everything. - MissInformation [more]
Go Back   Chief Delphi > Other > FIRST-related Organizations > FIRST Scouting Network
Unread 12-10-2003, 01:56
Jack's Avatar
Jack Jack is offline
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
XML Parsing
Hey all..
Well.. I decided to start working of FSN and make some nifty code.
Anywho.. I wrote this function that will take virtually any XML and turn it into a nifty array.
Now that I have the array, i'll be working on a script that will take FSN xml, validate it against whatever "standard" that xml is using, and then insert it into the db. (Give me a few weeks for that )
anywho.. the code..
any suggestions??
edit: Well... vB did a great job of removing necessary things from the code like \ 's when i directly posted it here. So.. i've attached the php file (saves as txt)
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 12-10-2003, 13:36
Jack's Avatar
AKA: Andrew Schenk
wheee..
ok.. so the little "short-cut" that I posted here, I fould actually didnt' work
anywho.. here's the good version.
XML And Link Raven_Writer Website Design/Showcase 13 26-09-2003 17:24
xml Jack FIRST Scouting Network 0 01-09-2003 16:23
[Tech] - XML Parsing Jack FIRST Scouting Network 3 20-05-2003 16:42
Listen-to xml parsing example thingie Trashed20 Website Design/Showcase 4 27-03-2003 15:13
XML to MySQL apk Website Design/Showcase 9 17-01-2003 23:13
