Go to Post ...if you say "AndyMark" three times we show up... - Billfred [more]
Unread 13-10-2003, 21:36
hold? it sounds like you are asking how much pressure can you put in the piston? if so, that is spec'd out for the pistons by the manufacture
if you mean, how much force can the piston deliver when actuated, multiply the air pressure you are putting into the piston (PSI) times the area of the cylinder inside diameter (in sq inches)
for example, a piston with a 2" inside diameter is PI * R^2 = 3. 14 sq inches
so if you apply 60 psi it will push with 3.14 * 60 = 180 lbs of force.
Is that what you are asking?
Inverse Tangent D.Viddy Programming 10 25-01-2003 22:24
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
