#16
Search engines don't care WHAT makes the html they're parsing.
<h1>Hi</h1> as outputted by a PHP script is the exact same as <h1>Hi</h1> as outputted by a Perl script (which is what I believe MT is). A static webpage is a completely different entity than what google caches. Google caches "snapshots" of the page. Thus, what is outputted by b2 is going to have the exact same weight as the output of MT. Do you understand what I'm saying thus far? For the purposes of actually parsing the HTML and all that, it doesn't really care what makes the page (and probably can't tell anyway) Now then, what DOES make a difference, and maybe what you were thinking of is the fact that google does figure out that pages are dynamic. (I believe this occurs when you have querystrings, IE: index.php?view=foo). What googles does is then not index as deeply, because its dynamic, who knows, it might go into an infinite loop (the URLs are all different, say for a visit-tracker) Quote:
Oh, and why must you make every post orange? I have some serious vision impairments, and its causing me problems reading your posts. :-X (Excessively bright color on relatively bright color) |
#17
Rather than going on about this debate I employ you to read a little into what I am talking about. In general HTML only pages are better than on-the-fly pages everytime, guaranteed. Secondly, most of these content management systems have no standards support thus hindering their performance even more. MT is the best standards supported CMS and it creates static pages, that's just about the best you can do when trying to get hits and improve your website presentation. RSS feeds is another good addition that MT has that these other CMS systems do not and finally all your MT blogs will be automatically advertised by MT themselves, makeing an even greater impression. Now the article: http://www.alistapart.com/stories/seo/
#18
Give me an actual arguement better than "its better". That isn't an arguement, thats an opinion. Quote:
Also I am not making fun of b2 or saying it is bad, in fact I quite like b2 as it is almost the same thing as MT. But there are many differences that do not make me like b2 for instance, b2 uses all dynamic content which I have already addressed, b2 needs to be installed anew for each blog you want to maintain whereas MT does not, MT allows you to have notifications and subscriptions to posts, and the MT interface is just much more professional.
#21
HOWEVER! And this is the point you seem to be missing, I can make b2 create URLs like foo.com/b2/archives/2003/09/03/ just like in MT! Not only that, but even that is not the full story. :-P You see, you can even customize the URLs that are created. ![]() Quote:
Now then: standards compliance: I brought it up because you brought it up. The default template is MORE standards compliant than MT's. b2, by DEFAULT uses divs instead of tables to create containers and create the layout. I'm just saying that MT makes it harder for you to make XHTML2 sites (as opposed to HTML, or even XHTML1). XHTML2 requires a mime-type of (I think) Application/XML or something like that. Quote:
![]() Quote:
Standards = good. You're preaching to the choir here though. Again, WHAT advantage do you gain from static content that isn't more than made up for by the simple fact that dynamic is dynamic, write a template, and update content on the fly? URLs can be rewritten with apache (thus negating your google arguement). And that appears to be your only arguement on that regard. Here, I'll repeat that arguement, so that you'll get this, because that is the ONLY reason I started talking. You can rewrite URLs in apache, so that search engines think you're just giving them files from off a hard drive in a directory struture, so that they don't realize that its a dynamic site! And here was my clarification that I posted a few posts back which argued against the exact point that you just stated. Quote:
#22
I never said that changing your mod_rewrite (yes I do know what you are talking about) isn't a good solution, it most certainly is but think about it like this. You start off with b2 as is, you install it for your site, that's all good and done. Now you say you have to edit some settings etc to get the urls to work properly. Alright fine, assuming your host lets you do that (I am sure most do). Well you just did something that not every team in FIRST can do but kudos to you except now many other teams that don't know how to do this will already be affected.
Now you have a site with good urls, but it still uses some tables for layout of the site which you now have to change if you want to have good standards related site design. Though using tables is fine by w3c.org, it's still not a good way of laying out content unless you have tabular data. Now that's another thing which some FIRST teams may not know how to do but it's not too big. So now you have something that is very very comparable with MT but the fact is you just wasted time to create something that was already existant. In the end you get the same result but my point was that MT default config is perfect in every way for search engine placement. So you can use b2 since you are familiar with it but please do not think that everyone else is as technologically savvy as you are. Sure I generalized that dynamic pages are worse than static but there is reason to my claim. Once you deal in a professional web enviroment you will learn that it becomes easier to teach people a tool that is close to perfect instead of making one that is. One last thing about b2, it still doesn't have the notification system builtin which is another reason I suggest teams not to try it out and the absolute worst thing about it is you have to install a fresh copy each time you want to add a blog, this again is very unproductive. With all that being said this thread is basically dead to me so please dont' expect a response to anything else. People now have more than enough information to pick what they believe to be best. |
#23
Too bad you are wrong?
b2 uses a theme similar to the bluerobot theme to begin with. (which I mentioned earlier. b2 does NOT use tables, except for the calendar!) BTW: MT and b2 are written in different languages. I chose b2 because for a long time I didn't have perl, but did have PHP. Whats the notification system? I'm not familiar with that? |
#24
The notification system sends an email out to you whenever you get a reply to your blog and it also allows you to add people to a list so that when your blog gets updated they get an email.
Also, one more thing about dynamic vs. static... if anyone is familiar with gzip they will know that it only works on static pages. What gzip does is compress your page and send it over the net so the end user actually gets the page faster than if they did without it. Of course your host has to support mod_gzip for this to work but most do. |
| What type of plastic is the | Adam Y. | Technical Discussion | 1 | 01-28-2003 06:03 PM |
| Can I use any type of switch on my controler interface? | archiver | 2001 | 5 | 06-23-2002 11:09 PM |
| What type of bot will win Battlecry? | Rick | Off-Season Events | 14 | 06-12-2002 09:36 PM |
| WASH scouting fields | Mike Soukup | Scouting | 0 | 02-04-2002 02:39 AM |
| Spacing of jugs and moveable goals | luccul | Off-Season Events | 3 | 10-24-2001 09:01 PM |
