Go to Post When it is so boring and slow on here in the summer it is funny how all of us just jump at something technical. - sanddrag [more]
Unread 22-10-2003, 18:57
mrman15 mrman15 is offline
mrman15 is an unknown quantity at this point
Quick C Programming Q
Ok, I'm making the switch from Pascal to C, and I dun no the name of the program I need to write C (like you use turbo pascal to write in pascal). If someone could give me the name of a program it would be much appreciated. Thnx
-Chris
Unread 22-10-2003, 19:13
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
go here get that...
The Default code and other info is available from Innovation First.
Default code here and other stuff
The IDE (integrated development environment) and compiler are from MicroChip -- the licensed copy will come with the EDU kit (I suppose). But, you can download a 60 day trial version of the IDE and compiler from microchip.com
Download MPLAB IDE and MPLAB C18 Compiler Trial Version Here
Good Luck...
Joe J.
Unread 23-10-2003, 08:50
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Re: Quick C Programming Q
If you want to practice programming in C on a PC, you can get one of the following compilers:
Microsoft Visual Studio
Borland C++
Watcom C++
Gnu gcc (Gnu is free for download, but you need to learn how to write make files).
Programming Compatition Angela06 Programming 30 08-04-2005 23:12
Q&A Discuss: Quick C Programming Q CD47-Bot Extra Discussion 6 16-11-2003 11:16
programming newb JP_1163 Programming 4 08-02-2003 23:33
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
pbasic programming punarhero Programming 4 21-01-2002 23:32
