Go to Post There are 10 types of people in the world: those that understand binary and those that do not. - Stephen P [more]
Unread 21-10-2003, 16:29
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
Help:animated tank tred
Hey, i need help knowing how to make an animated tank tred in max. I know there is an easy way ( i saw ted boardman do it once ), and i just can't how remember. If anyone knows how, or knows of a good tutorial, please hook me up!
Thankx.
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Unread 21-10-2003, 18:00
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
I think I once saw a tutorial (maybe at 3dcafe.com?) that made one link of a tread, made a whole bunch of them in a line using an array, and then path-constrainted them all to a sort of oval shaped spline. Hope this helps.
Edit: found that tutorial: http://3dcafe.com/asp/tutorials/max/...k/cattrack.asp
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 21-10-2003, 18:23
...............'s Avatar
............... ............... is offline
............... is an unknown quantity at this point
Send a message via AIM to ...............
constrain each center point of the treads.
or just motion paths that the treads follow.
if you are moving over an illregular surface then just create clusters on the motion path that are constrainted to be x amount of inches/mm/feet/cm from a designated surface.
Max should be able to do some of this..
its pretty basic.
I don't think she could have gotten his whole finger in one bite though, that part was kinda far fetched...
Unread 22-10-2003, 15:50
Hoonigan
no team (no team)
More help needed.
How do i attach several items, so that they become one object? I can't use groups, i need one mesh or whatever. What do i do?
-Alexander S. McGee
Unread 22-10-2003, 15:59
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
simple draw one link, make an array and space them so they link up, attach them so there one object, make a spline, an elipse or a connect the dots for path of the tread, and use the modifer assing path and select the spline
it works with treads chains belts etc...
Unread 22-10-2003, 21:59
djcapelis's Avatar
djcapelis djcapelis is offline
Fried Manic Custard
None #0675 (Geeks with Power Tools)
djcapelis will become famous soon enoughdjcapelis will become famous soon enough
Send a message via ICQ to djcapelis Send a message via AIM to djcapelis Send a message via Yahoo to djcapelis
*Mutters something about edit mode and crappy max...
"I have more friends than enemies, I'm working to resolve the issue."
Unread 23-10-2003, 00:36
D.J. Fluck
Posts: n/a
Contact Dan Ward from 45. Him and his brother Luke figured out some way to do that and did it back in the 2001 animation that we put out.
Unread 06-11-2003, 19:58
FRC #0701 (RoboVikes)
It is very easy ... first draw one link...then shift drag it the distance you want it from the other one... next type in the amount of links you want..
now create a closed spline the shape of your tread, after this simply apply path deform modifier and play with the settings u'll get it its's very easy
Team 701
Unread 12-11-2003, 11:10
APRUZ17 APRUZ17 is offline
#0007 (Oaktown Crewz)
APRUZ17 is an unknown quantity at this point
The real thing behind what you want to do is how detailed you want your tank tread to be. If you're looking for high quality detail you may want to take a quadpatch or a plane with lots of segments. You can then go into Photoshop and make an outline of the tread you want into a displacement map (If you need a larger explanation of this I can make one for you) and apply the map to the plane or quadpatch. This creates very detailed treads.
To animate a tread or chain I'd suggest making a spline of where you want the chain to be, then duplicate the individual part of the chain/tread and use the modifier (Modifier tab> Path Deform). After this you can use the options to place the individual pieces of the tread and use the percent tool to make them go around.
M. Hallock
Dondero High School
Unread 12-11-2003, 17:49
Matt Hallock Matt Hallock is offline
#1188 (Oaktown Crewz)
Matt Hallock is on a distinguished road
Send a message via ICQ to Matt Hallock Send a message via AIM to Matt Hallock Send a message via Yahoo to Matt Hallock
That's me above, I was posting under a friends account at school. You can contact me on ICQ or AIM if you have more questions.
Lead Animator for Donder-Kimball High School, team #1188.
Unread 13-11-2003, 10:32
ON second thought this isn't an EXACT way of doing it... because as u've seen the treads flex at the curves and they shouldn't this is incorrect... that is...using path deform... any one have ideas on how to animate it so it looks EXACTLY like the real thing...(no flexing treads)
Team 701
Unread 13-11-2003, 10:49
Out of curiousity, what tank are you modelling? Some of the older tanks from World War II and World War I had steel type treads and had no flex to them, nowadays some of the tank treads like on the M1A1 Abrams has flex to it so they don't break on rocks or sharp material, along with a type of matting on top of the treads.
I think I have a freeware plugin that reduces the amount of deformation on the path deform. The reason there is deformation is because if the curve changes quickly, the object compensates for it and it deforms.
Unread 17-11-2003, 10:34
Go here and go to the plugins page. Then look for "Normalize Spline." It gets rid of a lot of the deformation, I'm not sure if it works with MAX 5 on up though.
Unread 25-11-2003, 21:58
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
Ted's training site.
Here is the Autodesk trainign vids. I am pretty sure this is what you were talking about. i believe it has Ted doing a low poly tank w/ a tred.
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
tank treads vs. threaded wheels lj8758 Technical Discussion 14 24-01-2003 00:30
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
Filling Pneumatics tank? archiver 2000 2 23-06-2002 22:47
pneumatics tank archiver 2000 2 23-06-2002 22:43
Filling the pneumatics tank archiver 2000 4 23-06-2002 22:43
