Go to Post Of course 254 owns Battlebots too - dodar [more]
Unread 23-10-2003, 01:06
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Originally posted by Dan 550
I'm bettin that you can find your formula here in this file. Now I have no idea what the formula is -- I've never really felt a need to calculate ratios exactly for our robots -- but this paper sounds pretty fly so check that out.
Incidentally, this paper deals mostly with the characteristics of the robot's wheels as they turn and slide on the ground, especially as that relates to turning ability. The paper doesn't go into selecting the correct ratios between individual gears, rather, it advises you that you'll want to make a few calculations to ensure that whatever you do, you make sure that your gearboxes can put out enough force to allow the robot to tank-steer. Choosing individual gears is an entire subject unto itself. You'll have to take into account everything from size and weight to cost and availability of parts (and many other factors).
