Go to Post An opportunity is always there waiting to be discovered, we just have to look and then see what we can do to help create change. - JaneYoung [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 24-10-2003, 14:14
gail gail is offline
#0469 (Las Guerrillas)
gail is a name known to allgail is a name known to allgail is a name known to allgail is a name known to allgail is a name known to allgail is a name known to all
shaft connectors
May we use the kit shaft connectors on ALL the keyang motors (square and integrated shafts)? The kit only came with two and we would like to use 3 or 4. I assume these are fasteners and are not a problem, but wanted to check.
Slip connectors (custom electrical connectors) Damian Manda Electrical 2 08-02-2003 17:53
Motor coupling archiver 2001 19 23-06-2002 23:35
shaft drive Joseph F Technical Discussion 5 03-02-2002 17:51
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
45 or 75 amp anderson power products connectors to drill motors? Andrew Wyatt Motors 2 20-12-2001 08:00
