Go to Post hmmm... big open space between arena and pits... thousands of poof balls...thousands of high school kids hopped up on sugar and robotics.... sounds a little dangerous. - Courtneyb1023 [more]
Unread 09-02-2002, 10:19
Mike o.'s Avatar
Mike o. Mike o. is offline
AKA: Mike O'Brien
FRC #1086 (Blue Cheese)
Mike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud of
Send a message via AIM to Mike o. Send a message via Yahoo to Mike o.
Electrical
Are we alowed to use a sonaelrt on our operator interface????
Mike O'Brien
Team 384
Unread 09-02-2002, 21:47
You have no restrictions on what you can use with the OI, other than the signal coming from the OI LED outputs is limited to about 10 mA, if that is what you want to drive the Sonalert. And if that is not enough to power the Sonalert, be careful not to require AC power.
Unread 10-02-2002, 10:33
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
No restrictions is a bit of an overstatement. If I understand what a Sonalert is (a buzzer of some sort, right?) FIRST might have a little trouble with that. We can't use lighted switches, but we can pull +5V off of the joystick ports to drive LEDs. Strange, but them's the rules.
I would suggest that you post the question on the Yahoo question site. Just to make sure.
An alternative is to modify the Dashboard program and bring up a laptop. You have more latitude with what you do that way. You can make the laptop buzz or flash red on the screen. With all of the noise on stage, I think visual cues are more effective.
Warren B
Pool Noodles. They're not just for bumpers anymore.
Unread 10-02-2002, 21:51
Both replies are correct in this respect...
The rules allow you to design any type of operator interface within the guidelines that the digital outputs can be used to drive LEDs but are current limited to 10ma each. 10ma is capable of lighting a single LED but just barely and you only have five volts available when the ouptput is "high". If your Sonalert fits that criteria, 5volts @10ma max you might be good to go. FIRST has limited sound at competitions and may frown on sounder devices in the player station. Finally, if you are a rookie team, I can tell you from years of experience that a sounder will have to be really loud to hear over the roar of the crowd.
Good Luck All,
buttons (continued from post in electrical) rosebud Programming 3 11-01-2003 17:34
How does your team organize its electrical supplies? Josh Hambright Electrical 8 28-11-2002 13:01
Drill motor copper electrical connector archiver 2001 1 24-06-2002 00:57
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Robot electrical systems rules Morgan Jones Rules/Strategy 5 06-01-2002 00:50
