Go to Post Just a word of advise dont come running up to someone and say OMG OMG its just remember to introduce yourself first. - Mike Schroeder [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 24-10-2003, 23:10
codeoftherobot's Avatar
codeoftherobot codeoftherobot is offline
Safety General
FRC #1097
codeoftherobot has a spectacular aura aboutcodeoftherobot has a spectacular aura aboutcodeoftherobot has a spectacular aura about
Our EDU finally came today. I thought FIRST were supposed to ship the EDU's out a while ago but at least they came. We were actually supposed to receive the EDU yesterday but it arrived today. Wonder what went on?
Sacramento Regional 2003 -Rookie All-Star Award
Silicon Valley Regional 2003 -Rookie All-Star Award
Sacramento Regional 2004 -Autodesk Visualization Award
Sacramento Regional 2004 -Regional Engineering Inspiration Award
Silicon Valley Regional 2004 -Johnson & Johnson Sportsmanship Award
Cal Games 2004 - Finalist (thank you 968 and 114!)
Sacramento Regional 2005 - #1 Seed Team Regional Finalist (with 254 and 114)
Sacramento Regional 2005 - Johnson and Johnson Team Sportsmanship Award
Unread 25-10-2003, 00:44
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
FIRST used ground shipping.
I FINALLY got to the point of being able to compile and upload to the new eduRC. Whew.
And, the results are really cool. While we still don't have our R/C controller yet, I programmed it to do a few things. First off, I'm using my crab-drive edubot that I built before we got the new controller. I've gotten it to basically strafe around in different shapes, circles, triangles, squares, etc.
I'm having a bit of a problem w. the servos though...
The Range of the pwmXX variables is still 0-255, right? For some reason, The HiTec Servos from last year's kit wont go all the way around to 0 when 0 is sent, and wont go all the way around to the other end at 255. They do center at 127, though. I tried a few different things, but I'm still having some issues getting them to go from 0 deg (0) to 90 (127) to 180 (255). And Yes, I know that the servos actually have over 180 degrees of rotation, so these numbers aren't 100% correct, but the problem is that they won't move enough. I'm not sure why. In all my previous work with servos, I haven't had this problem...
Anywho, I'm trying to find a small portion of free web space I can link to to post up some video of the bot in action. We're still in the process of getting our "new" domain set up.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 25-10-2003, 10:05
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
servo range
Are you sure about the servo range? I had a HiTech servo that only had a range of about 100 degrees.
Unread 25-10-2003, 11:11
Sachiel7's Avatar
AKA: Shayne Helms
Yeah, I'm pretty sure, but maybe you're right.
The servos I'm using are from last year's kit.
Hey, It's good enough for me to get it to do a few shapes, so I'm fine for now.
I really like the fact that it can be programmed to run without any special equipment. I already have tons of auto modes programmed within just one day! And, you can switch betwen them easily.
I'm still searching for some free web space to upload some videos of the MiniCrab in action...
-=Sachiel7=-
Unread 25-10-2003, 12:36
AsimC AsimC is offline
#0871 (West Islip Robotechs)
AsimC will become famous soon enough
nice...so do i... but how do you easily switch between them? i just have separate .hex files.
WEST ISLIP ROBOTECHS - Team 871
-2004 SBPLI REGIONAL CHAIRMANS AWARD WINNERS!
-2003 SBPLI Regional Finalists with 545 and 566
-2002 SBPLI Rookie All-Star
-Former Student Team Leader and Programming Head
Unread 25-10-2003, 13:55
Sachiel7's Avatar
AKA: Shayne Helms
I use this method:
F_Count > Function Counter. This counter is set at the beginning, and performs a task based on it's number.
T_Count > The number in seconds for each task (F_Count) to be performed. This could be turned into an array for separate times per function.
counter > A temporary Cycle counter. The Main User Routines (17ms) loops about 58 times/sec. So, the main loop thus contains:
counter ++;
if (counter > (T_Count * 58))
F_Count ++;
counter=0;
Then, we simply check the value of F_count to define the robot's Current Functions:
if (F_Count == 2)
pwm01 = pwm02 = 254;
pwm03 = 0;
pwm04 = 254;
Now, I could use a switch instead of a bunch of 'if's, but the last time I tried the compiler didn't like it...
So, F_Count 1-10 could be one function, 12-16 another, etc. You need to alot one extra value check for each main function to reset it, if you want it to loop:
if (F_Count == 11)
F_Count = 1;
etc.
The way I'm currently switching between them is in the programming. I just change the F_Count's Initial Value, and T_Count's value accordingly.
You could easily set up your digital i/o pins so that you can install a jumper on a set of pins and it will trigger a certain auto mode. I'm working on something like that now...
-=Sachiel7=-
Unread 25-10-2003, 14:05
haha..yea i had the same problem w/ switch
anyways..thanks for the info..
Unread 25-10-2003, 17:31
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
I just installed the software, compiled a program, and down-loaded the code. The down load only took a few seconds (10-15) much like the previous year's controller.
I originally tried to install using Crossover Office (under Linux). No real success.
I then attempted Windoze ME. OK on the MPLAB stuff. No success on the IFI.
Finally, I installed under Windoze98. All went fine.
Thank goodness they supplied us with the EDU controller and compiler NOW. I cannot imagine trying to deal with these issues along with everything else in the build phase.
I anticipate many late nights loading code into the EDU controller before January.
Unread 25-10-2003, 21:11
marlon_jbt's Avatar
marlon_jbt marlon_jbt is offline
FIRST IS LIFE... 4 years later too!
FRC #3322
marlon_jbt is an unknown quantity at this point
Send a message via AIM to marlon_jbt Send a message via Yahoo to marlon_jbt
We received our EDUBot on Friday
And haven't had much time to do anything with it yet...it's just sitting there.
I was amazed at the small size of the new contolller compared with the one from last year! Reminds me of that Subway guy!
|l ,[____],
l---L –OlllllllO-
()_) ()_)----)_)
Unread 26-10-2003, 09:15
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Anyone here in Canada gotten their's yet? We haven't.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 07-11-2003, 11:16
our team hooked the new EDU controller to an R/C system we had from a few years back (that we used for older robots)
I think its an AirTronics 4 channel FM system (will check later)
it worked perfectly - students had our EDU bot running around in no time at all, using the default code in the controller.
Personally I like the new hobbie R/C transmitter setup - it lets you put the whole EDU kit into a container (from last years game) and carry it around - and we dont have to share the Operator Interface with the full sized robot anymore.
and, now we have two Robot controllers for the EDU kit, the new one and last years, so you could build two robots with the one EDU kit, and have mini competitions if you really wanted to.
Unread 07-11-2003, 16:24
Argoth Argoth is offline
AKA: The Prez
#1255 (Team Blarglefish)
Argoth can only hope to improve
ours came in today anyone know what the coeffecint of friction is for the wheels, i am guessing 2 or 3
BEWARE OUR ROBOT, It has serious anger issues. Prone to attack whatever is infront of it randomly! Tried to cut our sponsors jugular!
"A common mistake that people make when trying to design something completly foolproof was to underestimate the ingenuity of fools." ~Douglas Adams~
Unread 09-11-2003, 23:29
I checked the radio system we used - its a HiTec, not airtronics.
BTW - for the post above ^ the coeffecient of friction is always less than 1 - you cant have a stonger fiction force than the normal force, unless the material hooks or glues itself to the mating surface.
Unread 09-11-2003, 23:45
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Off-topic, but what's the rationale behind stating that mu < 1? As examples, here's a potentially contradictory explanation (http://mathforum.org/library/drmath/view/51493.html), and here's a spec sheet for sorbothane (a plastic foam) that neither adheres nor hooks onto any other surface (http://www.sorbothane.com/PDF/sor_matprop.pdf). They report a static coefficient of friction of greater than 15 under certain conditions!
Unread 10-11-2003, 04:27
Electrical Engineer
Rookie Year: 1995
Tristan,
A "sticky" subject indeed. All references are correct. For most all applications, mu is indeed less than one, however, it is not a physical requirement.
As an example, I ask that you consider one of nature's most amazing substances... Water.
When a skater is gliding across the ice, the weight of the blade of her skate causes the ice to melt and this lubricates the ice/blade boundary to a very small value of mu.
Now for an old fashioned dinner table experiment. Take a standard teaspoon, clean both the spoon and the end of your nose with a clean napkin (this gets rid of grease). Next, breathe heavily on the spoon to create a light layer of condensation. Now you can "hang" the spoon off the tip of your nose demonstrating a mu of > 1.0 for the very same substance (water).
In our first example, water is a "lubricant" and in the second it is a "glue". Both actions must be examined on an extremely small scale to be understood.
In general, Ken is correct. For mu > 1 there is usually a hook or glue mechanism at work. Just remember, the action might be taking place at the molecular level...
Mike Betts
As easy as 355/113...
Should all three pneumatics pistons have been received? Jordan A. General Forum 6 08-01-2002 13:48
