Go to Post Umm, guys, the stacking game was last year. Toss the Genia is much more appropriate for Aim High. - Greg Marra [more]
Unread 26-10-2003, 22:36
dddriveman's Avatar
dddriveman dddriveman is offline
Former Driver 1038, 979
AKA: Driveman
FRC #1038 (Thunderhawks)
dddriveman has a spectacular aura aboutdddriveman has a spectacular aura about
Send a message via AIM to dddriveman
Best Body shape?
What do you think the best shap of a robot body is?
i.e triangle
square
circle
"I'm sorry, after all he is just a wookie!"
Unread 26-10-2003, 22:40
one like a pancake, that can run downside up
then you can name it:
pompous snodwod
cause its name will be the same upside down and verse visa.
Unread 26-10-2003, 22:46
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
Best body shape is whatever you can make antimatter look like.. cause then you can transport your opponent to an alternate universe.. so, go for prototyping that... just be careful you don't make yourself go away on accident
*edit*
Make it a hovercraft as well, cause an antimatter hovercraft robot would be awesome.
Chopsaw? Chopsaw.
Unread 26-10-2003, 22:51
I wonder how many times FIRST has been asked THAT question after the kickoff meeting:
"Ive got this idea for our robot, but Im not sure if the rules allow it. Is transporting your opponent into a parallel universe against the spirit of the rules?"
but I digress.
I think for each year, teams should start out with a basic two wheel design, dragging a castor for stability
then only make the drivetrain different if absolutely necessary.
also, a round chassis that spins on two wheels can never get stuck in a corner, or against a wall. but a circular chassis is not easy to make.
Unread 26-10-2003, 22:57
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
you Know im rigging Gullwing Doors and a Flux-Compacitor up in the 2K4 Swampthing
Unread 26-10-2003, 23:23
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: Best Body shape?
i.e triangle
square
circle
Driveman,
The shape of the robot shouldn't be determined ahead of time. As you design your mechanism, let the robot chasis grow organically around it. A perfect melding of form and function.
This way, you'll have plenty of room to integrate the kill-saws.
Seriously... a simple square "base" with some mechanism on top usually works well. Some teams design their robot chasis/drive ahead of time. Some tweak these designs to accomodate a "ball chute" or other mechanism. Others design the robot around the mechanism, or make the chasis itself part of the mechanism.
Do whatever you feel comfortable with.
John
Unread 27-10-2003, 00:31
Dan 550's Avatar
Dan 550 Dan 550 is offline
Behold the Awesomeness!
AKA: Dan Richards
#0550 (BattleTech)
Dan 550 is on a distinguished road
Go modular. Being able to piece it all together easily, just putting together four fasteners and a wiring harness for every piece of your robot is essential for ultimate goodness. And make sure your left and right motors turn the same direction.
I never follow my own advise.
Unread 27-10-2003, 09:06
dddriveman's Avatar
AKA: Driveman
I have a really cool idea for a body. I spent a bout twelve hours straight on the designing. It was a real headach but i believe that it will be worth it. I already have wheels and gears drawn in. I dont have motors yet because i don't know what kind we will get. I will post it later after i get access to a scanner. B/c i had to draw it by hand.
Unread 27-10-2003, 16:20
MisterX's Avatar
MisterX MisterX is offline
Alumni
AKA: Mr. X
FRC #0521
MisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to behold
Last year one of the body designs shot down for are KOH was an tirnagle thing with tow sides the same compltly drawing a blank on the name right here but basically it had treads on the edges sitcking out on all sides so we could run on all sides of the triangle and plate that came down to form a bridge up for the bins. We would stick to the top with friction pads of sort that woudl lift us off the groujd so the treads could also act as conveyor belts. But the idea was scrapped for one reason or another anyway Long story short build the shape arounf ur design not ur design around the shape
Unread 27-10-2003, 16:22
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
honestly, the best body shape would have to be a sphere... i mean common, and if you can make one of those sheres that absorb things, you will be set
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 27-10-2003, 16:41
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
Most teams build square bases. Many of these teams have the resources and creativity to build the best base possible, yet the square bases still persist. This leads me to believe that the best body shape, within reason, would be a square.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 27-10-2003, 16:48
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I think y'all mean rectangular when you say square, right? I mean, otherwise, what a waste of space.
--Madison--
...down at the Ozdust!
Unread 27-10-2003, 17:00
Specialagentjim's Avatar
Specialagentjim Specialagentjim is offline
"I am a Meat Popsicle"
AKA: Jim Martz
None #0108 (SigmaC@T)
Specialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to behold
Send a message via AIM to Specialagentjim
Hahaha, I that brings back memories of "Team such and such would like to request that if anyone has any...umm..flux?..compacitors, that they loan it to them. Thanks"
I am soo making sure 108 is the first to ask that at regionals, heh.
Anyways, I prefer Rectangle. It fits easily into the size requirments, gives you the maximum wheel base, gives you four definite sides for slamming up against things and bots with, and leaves you with easily machinable parts (no trying to figure out how to build a circular piece of sheet metal in the pits if your armor breaks loose :-P )
Curie Division 2005 Champions (175, 33, 108)
UCF 2005 Website Award
Midwest 2005 Delphi's Driving Tomorrow's Technology
2004 UCF QuarterFinalists (1065, 86, 108)
UCF 2003 Regional Champs/Entrepreneurship Award
Midwest Regional 2003 Leadership In Controls/Website award
Nationals 2003 Quarter Finalists
Robot Rodeo 2003 Champions (Alliance: 180 and 186)
AIM S/N: Specialagentjim
Unread 27-10-2003, 17:04
Anthony's Avatar
Anthony Anthony is offline
FIRST Addict ... Er ... Mentor
FRC #0900 (Team Infinity)
Anthony has a spectacular aura aboutAnthony has a spectacular aura aboutAnthony has a spectacular aura about
Send a message via AIM to Anthony
Bot Shape
Personally I am all for the sphere idea, but good luck getting that to work in a KotH.
A circular base has lots of advantages you dont have to worry about corners on the playing field, you dont have to worry about protecting your corners, and the strength of a perfect circle is very nice, but there is also the problem that the size limitations are rectangular, so your robot would have a major size disadvantage seeing as you would have to build up instead of out, which is horrible for balance.
Triangle is just odd although if you did something like a triganol pyramid (4 triangular faces) then it could be rather useful if you were flipped or something because with just 4 wheels, two along one edge and two along its opposite skew edge, you would always have driving wheels on the ground. But yet again this is faced with the size problem.
Square, or rectangular, is seemingly the best of what you listed simply because of the way size regulations are set up. With the box your robot has to fit in having a rectangular bottom, the best way to optomize space and sit as low as possible is to spread out as far as possible in that box.
Personally though I think a design for a pentagon shaped bot would be cool. However, you can't completely determine the shape of your bot until the game is released, you do need to build your robot around the game and not around what everybody else does. I know our bot will most likely be rectangular again this year, but we will once again be more concerned with our drive train than we will with shape. I know last year we were one of the few robots that had multiple gears and could shift them on the playing field.
Good luck with whatever you design though.
Unread 27-10-2003, 17:44
Umm Errr...
Smile flux capacitors ehh
Technically, an electric permanent magnet motor with a flywheel could be considered a "Flux-Compacitor" (ahem flux capacitor). Apply current and the flywheel spins up. Remove the current, and te flywheel continues to spin, inducing a magnetic flux field around the windings.
Now gullwing doors? What is a gullwing door?
1139 Alumni
Any body have.... Alex Cormier Regional Competitions 0 03-04-2003 18:32
Any body know any Alphawolf829 Off-Season Events 0 28-03-2003 15:30
Does any body know any good ways of doing this archiver 2001 0 24-06-2002 00:27
Does any body know any good ways of doing this archiver 2001 2 24-06-2002 00:27
Any Body Know A Good Scouting Software? Joe Matt Rules/Strategy 0 14-01-2002 11:28
