Go to Post People will only work toward common goals when they are part of the goal-setting process. - GaryVoshol [more]
Unread 09-02-2002, 21:40
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Question mating motors
would any of you feel different mating the drill motor and the FP motor running through the drill motor gear box with the new FP motors and their increased power?
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 09-02-2002, 22:14
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
nope we're doing it
check it out:
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 10-02-2002, 05:11
Jon Lawton Jon Lawton is offline
Bitter FIRST Cynic
Jon Lawton is an unknown quantity at this point
Send a message via ICQ to Jon Lawton Send a message via AIM to Jon Lawton
You know, seeing all thsee really cool drive trains makes me wish our robot could have more than one drive system! Oh well, that just means we need to build more robots!
Unread 10-02-2002, 16:15
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Thanks goodness for safety factors...
I am really surprised at how well the drill transmissions must tolerate overloading conditions.
The gearbox that you see above puts something like 3-5 times the input torque into the transmissions than the drill motor hooked directly.
It is very surprising that these drills are designed with that much safety margin.
As long as the safety factor stays above 1 that is all you need.
Joe J.
Unread 10-02-2002, 22:30
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Re: Thanks goodness for safety factors...
Joe J.
I guess the question is......is this the "before" or "after" power-on picture?
-Quentin
Live free or die....
Unread 11-02-2002, 00:08
PMGRACER's Avatar
PMGRACER PMGRACER is offline
AKA: PAUL GIANNOSA
PMGRACER is on a distinguished road
Joe J.
Just wait till you see what Dennis and I created! Drill motor/Atwood motor combo running into a comman shaft. We pulled the first stage gears out and made an adapter to drive via the gear dowels. I am concerned we might toast the tranny if we get slammed in the oppisite direction when under full throttle, but I don't think the electric motors will deliver a sudden shock to the tranny the way I do in my 3500 lb.Camaro dropping the hammer at 8000 rpm and dead hooking! Broke a few trannys in my day. Since gone to a turbo 400 with a trans brake and a 5000 rpm stall converter.
In a preliminary drive test, we are making a bundle of torque in low range, and are almost uncontrollable in high. I agree that these transmissions are suprisingly tough. But driving screws into 25 year old pine puts a little stress on the trans too!
Racing is an incurable addiction!!
Unread 11-02-2002, 04:30
Bitter FIRST Cynic
Re: Re: Thanks goodness for safety factors...
Our team almost went that way, too. Now as we pop breakers with the drill motors in high gear (2:1 on output), I'm kind of wishing we did. :/
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Suppose you want seat motors... archiver 2000 0 23-06-2002 22:50
