Go to Post We build because we can. - Danaca [more]
Unread 27-10-2003, 23:32
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Need an EDU Beval Gear
Unread 27-10-2003, 23:33
Kevin A Kevin A is offline
In Hibernation
#0481 (DART)
Kevin A will become famous soon enough
Send a message via AIM to Kevin A
Could you take another tire and have them run perpendicular to eachother, and the friction would transmit the power?
Unread 28-10-2003, 00:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Hmm. Not a bad idea. I found these:
http://www2.towerhobbies.com/cgi-bin...?&I=LXDE95&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXFU85&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXKK04&P=7
All of them do come in larger sizes too but I thought you would want something small.
Unread 28-10-2003, 12:55
Rich Wong Rich Wong is offline
NYC FIRST Planning Committee Member
no team (NYC FIRST)
Rich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond repute
Send a message via AIM to Rich Wong
SWEET!
Any chance of a copy of the plans?
popularis de ob instinctus agnitionis scientia technologia
Home website: www.nycnjfirst.org
Member of NEMO & e^(i*pi)+1 Fraternity.
Member of Friends of Robots
Member of NYCFIRST Planning Committee
Unread 28-10-2003, 17:09
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Niiiice....
I made an similar crab-drive edubot, only problem is the wheels won't turn, it appears like there is way too much friction- do yours successfuly rotate?
Unread 28-10-2003, 18:04
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
it spins like crazy dude, don't even start
I still need a beval
Unread 29-10-2003, 21:47
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
You crab system looks much like my large scale design, Tytus, cool! I just screwed the wheel assemblies into 2 servos for my crab drive
The only prob. is that the servos only range 100deg, I need 180. I'm lookin into some new ones. But for now, that's what I'm doing.
I actually built a edu prototype of my full crab drive, and just stuck 2 of the gears together at 90 deg. They worked OK. But, I would look into getting some nice beveled gears. I think there's an easy way to mod up lego beveled gears to fit the edubot's shafts... I did it last year. I'll try and dig up that project...
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 30-10-2003, 10:12
AKA: Ty
edu is realy anoying me, there are only so many parts in the kit and there are only chains and sprockets. I used a Victor an FP motor on my hoverbot
as far as crab goes my turntables just came in from Pitsco and i built a coax lego crab with arakeen correction, i hope my Legoleague kids wont tear it apart for the motors untill i take a picture tho
Unread 30-10-2003, 14:03
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
bevel gears...
Berg sells miter gears that can be made to work with the EDU kit.
It will not be pretty but it can be done.
I recommend a 1 to 1 ratio with a relatively small diameter to keep "tilt" from disengaging your teeth ( like the pair M72N-1A for example).
This gear set is aluminum and has a 1/8 inch bore. You will have to make the hole square. To do that, I recommend the following broach from McMaster.com 3156A11 -- the problem is that it costs a bit more than I like -- but I have used it and they are beautiful for making EDU compatible square holes in aluminum parts).
Also, the pitch of these gears is a bit danty (72DP -- that means . You will likely have issues trying to get these gears to stay engaged reliably -- the teeth are only a little more than a half mm tall!)
To be honest, I suppose that for the most part, you could modify something from another toy set (Lego maybe) and have better success.
Good luck just the same.
Joe J.
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
Drill motor gearBox question Dennis Hughes Motors 4 11-10-2001 07:11
