Go to Post I think I need a bigger cup of coffee.... - JaneYoung [more]
Unread 28-10-2003, 20:21
GregTheGreat's Avatar
GregTheGreat GregTheGreat is offline
GregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura about
Originally posted by Al Skierkiewicz
Greg,
The 100 amp is fine. Remember the breaker is there to protect the battery from high current loads. Be sure to use the wiring specifications for size as listed in the robot manual and you should be fine. If you are going to use smaller wire, then you may need to go to a smaller circuit breaker.
The 60 amp breaker used in previous years was specially designed and rated for 48 volt DC operation so any old 60 amp breaker would not function the same.
The Anderson connectors work OK if they are propoerly terminated and are not damaged when inserted into the plastic block. A misaligned terminal causes a high resistance connection. High resistance and high current result in heating of the contacts and early failure. I just listed MCM as a source because I saw the connectors while paging through the catalog.
Thanks. I guess that sums it up, Thanks all.
-Greg The Great
$3500 limit - Who does not have questions Raul Rules/Strategy 5 12-01-2003 11:31
How does your team organize its electrical supplies? Josh Hambright Electrical 8 28-11-2002 13:01
pre-inspection preparation questions Adams High Man OCCRA 7 22-10-2002 22:22
Update 7 - Behind Schedule (or out of questions)? archiver 2000 2 23-06-2002 22:58
rules questions... archiver 2001 5 23-06-2002 22:40
