Go to Post steve, don't hurt me - Alex Cormier [more]
Unread 05-07-2002, 23:35
nwagers nwagers is offline
#0240 (Mach Vee)
nwagers is an unknown quantity at this point
Send a message via AIM to nwagers Send a message via Yahoo to nwagers
Vacuum
Has anyone here created a vacuum with anything that has been given to us the past couple years? Just curious
Unread 06-07-2002, 01:37
Stephanie Stephanie is offline
Stew da Baker
AKA: AKA: Steppie86
Stephanie has a spectacular aura aboutStephanie has a spectacular aura aboutStephanie has a spectacular aura about
Send a message via AIM to Stephanie
uhm, have you?
Unread 29-10-2003, 14:55
Jay05 Jay05 is offline
Jay05 is an unknown quantity at this point
bump....
has anyone?
Unread 29-10-2003, 15:03
I cant remember? does the compressor have an intake side that you can screw the filter off and put a fitting on?
if not, you can use the cylinders to create a vacuum - pulling the piston (with another piston) creates pressure on one side and vacuum on the other
just dont take it out into the woods, cause
nature abhors a vacuum!
Unread 29-10-2003, 19:46
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
vacuum
i will try to post some photos, descriptions and white papers if i can of our vacuum design that we created and manufactured as a team for the Stack Attack competition robot, in the next few days. It was a great device, and most people who have seen it and know how it works are impressed by it. I know i personally am impressed each time its activated.
~Mike
-Michael Dessingue
Unread 29-10-2003, 19:52
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: vacuum
I suppose someone could hack apart the compressor and turn it into a vacuum pump, or get or build a vacumm pump and drive it with a kit motor.
Unread 29-10-2003, 20:57
IMDWalrus's Avatar
IMDWalrus IMDWalrus is offline
This is a line...
AKA: Paul
FRC #0818 (Genesis '02)
IMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to behold
Send a message via AIM to IMDWalrus
Re: vacuum
~Mike
Definitely sounds cool, but I don't recall seeing your robot during the season. What exactly did you use the vacuum for? Stacking boxes? Moving them?
It's amazing what these robots can do...
Unread 29-10-2003, 21:06
Erin Rapacki's Avatar
Erin Rapacki Erin Rapacki is offline
General Manager
Erin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond repute
Send a message via AIM to Erin Rapacki
we made a very good vaccume without using the compressor last year... it's a cool idea
IM me, sn: errapi and i could attempt to describe it
http://www.linkedin.com/in/erapacki
BUZZ 175 (01, 02) - NUTRONS 125 (03, 04) - QUEEN 1975 (06)
Beantown Blitz Founder (04) - FIRST Robotics Conferences (04) - Boston Regional Volunteer Coordinator (06)
Unread 29-10-2003, 23:05
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
as of the 2003 season the only ways that you can create vacuum is to use a pneumatic cylinder or (i think) compress the air line. You could also get a suction cup that makes its own vac. when you say pull a handle.
The compressors don't have an vac. port on them and it is illegal to modify them to have one. Its also illegal to buy an vac. pump even if it is powered by an kit motor. However making one from a few small pneumatic cylinders and an kit motor is perfectly legal.. and has been done i think Erin's team did it but not sure
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 30-10-2003, 16:36
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Originally posted by Justin Stiltner
as of the 2003 season the only ways that you can create vacuum is to use a pneumatic cylinder or (i think) compress the air line. You could also get a suction cup that makes its own vac. when you say pull a handle. ...
I know we made a vacuum last year using a pnumatic cylinder, couple other cylinders (I think), and used a pressure gauge to regulate it at 60 PSI.
I will probably be able to get more info. on this later on in the week.
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 30-10-2003, 16:57
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Nobody has ever created a vacuum in FIRST robotics...
People have created partial vacuums, if that's what you mean.
There's a huge difference, a vacuum infers that there is no matter whatsoever inside the containment apparatus. With a partial vacuum there is air....
The difference is that with a vacuum the downward force exerted is 16PSI times the area of the suction cup.
With a partial vacuums, you have to use (16PSI - pressure inside) * area...
16PSI is standard atmospheric pressure.
There have been various attempts at partial vacuums... all methods employed suction-cup technology (as the rules state). Some just use regular suction cups, and press them to the surface, using force to remove the air and decrease the volume underneith the suction cup. Attempts to lift the suction cup then create an effective partial vacuum. At most, this system can only create equilibrium with the outside pressure. The partial vacuum is only created when you attempt to lift the suction cup.
Other attmpts include hooking the suction cup up to a cylinder, and then using another cylinder to increase the the total volume of the system, lowering the pressure. This, in effect, creates low pressure, and an overall downward force on the suction cup. This is much more effective than the first, because when you draw the cylinder, you create the partial vacuum. Any coefficient of friction between the surface and suction cup will be enhanced due to the downward pressure of the atmosphere.
My favorite, and probabaly the most effective, would be to use a one-way valve system and hook the suction cup to a cylinder. The air would be extracted from the suction cup (via equilibrium when you pull the piston), and then expelled out of another one-way valve. This would probabaly create the closest to a vacuum out of all three methods. I think I saw one team employing this method last year. I saw a motor driving a cylinder but I'm not sure if they were using a valve system (that would be pretty dumb if they weren't). As above, any COF would be enhanced.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 30-10-2003, 18:33
Isn't there a way to connect a cylinder to a rotating cam powered by a motor and have that act as either a compressor or vacuum pump by use of a one way valve? I know I've done it with legos.
The problem is (for a compressor anyway) that the assembly must be very rigid because it will want to blow it's mounting points if it compressing the air is very difficult. Also, it will shake itseld very violently when the psi's start rising.
So do we even get one way valves? We have never used pneumatics so far so I am not too familiar.
Unread 30-10-2003, 19:23
Go Badgers!
#0093
Although we don't get any valves that function with that respect in the kit, I'd imagine they exist. If not, then I'd be surprised. It'd probabaly be some sort of pressure valve. It could easily be created from some sort of rubber or silicone flap. When the pressure is greater the inlet side, the pressure forces the flap open and would equalize. When the pressure on the outlet side is greater, it would force the seal tighter.
There are pressure regulating valves at McMaster with a 0 PSI minimum differential, but I don't know if they are one-way... not to mention they cost $75 each...
Unread 30-10-2003, 22:11
The big guy
I think one team may have used the valves in the kit to accomplish this.. ie one opens, pulls air, then closes and another in the same line opens and the air is pushed out with the r/c controlling the opening and closing of the valves
Justin Stiltner
KI4URQ
Unread 30-10-2003, 22:23
You could have a switch located in a good spot on your vacuum pump assembly. When the cam rotates to a certain point the switch will be pressed. Then have the RC control a solenoid whenever the switch is pressed. Not too hard I suppose.
Suction Cups: How? Kai Zhao Pneumatics 25 04-02-2003 19:02
compressor? BBFIRSTCHICK Pneumatics 11 22-01-2003 07:12
Stacker with a vacuum Miles General Forum 15 17-01-2003 23:35
Hovercrafts Ian W. Chit-Chat 25 02-07-2002 16:06
Next Question - Check Valve archiver 2001 7 23-06-2002 23:18
