Go to Post Lesson learned, /always/ have a pick list! - Lil' Lavery [more]
Unread 28-10-2003, 15:18
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Compatible Radios
The other day we were playing around wiht the old 2002 robot and it kept doing this off and on thign and for the longest time its been doing that. after further experiimentation we determined it was the radio that was broken. but we can prove it unitl we replace the radio
The question is :
does anyone know if the 2003 radios are compatible with the 2002 robot controller and operator interface?
since our 2003 radios are fine and dandy they should prove that the 2002 radios are the problem
or does anyone know how to verify if they are working in some other way?
Thanks in Advance
-Osc-
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 28-10-2003, 15:21
the 2003 and 2002 radio 'sets' have different markings on them, so I dont think you can mix the transmitter from one with the receiver from another
but you could switch both and see if you robot works correctly.
Anther thing that makes robots wack out is when the battery is almost dead.
Unread 28-10-2003, 15:26
SpaceOsc's Avatar
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
oh yes indeed but the battery have always been good on it and since the very first days of the robot working when we built it its been that way but we never gave the radios working a second thought but now we have.
i did paln to use both and use the set thats why i was wondering if anyone knew the real answer before i start removing cables (its alot of work on our robot)
Unread 28-10-2003, 16:36
it cuold be the cable to the radio modules too
either in the robot, or at the operator interface.
Unread 28-10-2003, 16:41
ZACH P. ZACH P. is offline
Insert Custom User Title
#0321 (Robolancers)
ZACH P. is on a distinguished road
Send a message via AIM to ZACH P.
How did you determine that the radios were at fault?
But if it is the radios, do what Ken said and check the cables. Better yet, get two brand new serial cables for your radios. they were messed up for my team too.
pi is exactly 3
IM me at: zmstr265
Unread 28-10-2003, 16:43
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
During the 2003 season, we were fiddling with the radios, and we found that the 2003 radio transmitter can communicate with the 2002 and 2001 receivers. We never tested the radios the other way around, but that is the magic that we found.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 29-10-2003, 23:26
SpaceOsc's Avatar
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
Very Compatible Indeed
Hey i just went ahead and did it i changed the radios and swithc them from 2002 radios (both) to a 2003 system and 2003 radios to a 2002 system and both robots im ahppy to report run very well just for all of those who were wanting to also know
Unread 09-11-2003, 13:37
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
Yea, we've used every possible combination of Robot Controller, Operator Interface, and radio from the last three years and all are perfectly compatible (except the "disabled" light doesn't blink in autonomous mode on any OI except the 2003 model).
New programming language next year? Mike Alighieri Programming 131 13-09-2003 20:51
WE CAN USE ANY JOYSTICK??? cool. archiver 2001 9 23-06-2002 23:42
What subtitutes controllers, radios, Victors and Spikes? Digo Technical Discussion 6 15-05-2002 16:04
problems with receiving signals between radios (need help0 chrisw Technical Discussion 4 11-01-2002 10:35
Boosting signal on radios? Dave Hurt Technical Discussion 2 14-11-2001 16:07
