Go to Post As part of this test phase, I would expect to see Aidan sleeping on the job for most of the upcoming season. :) - dlavery [more]
Unread 09-02-2002, 23:56
Larry Barello Larry Barello is offline
http://www.barello.net
#0492 (Titan Robotics Club)
Larry Barello has a spectacular aura aboutLarry Barello has a spectacular aura about
How much code can an IFI controller handle?
I imagine this has been answered somewhere else before: But, roughly speaking, how much code can the IFI robot controller handle before missing packets?
I have heard things like 10,000 lines of basic/second which would imply ~250 lines of code.
Is there a simple way to determine when you start missing packets? Compare packet #?
Larry
#492 Titan Robotics
Unread 10-02-2002, 00:47
Dr J pointed out last year that you could, in fact, store 8 programs in the BS2sx, and have one program call the next into action, sharing between programs variables stored in a special way. Just in case you should worry about running out of space.
The whole topic is probably archived here, or you could check out parallaxinc.com for details.
Unread 10-02-2002, 00:51
The issue isn't code space, but timing: how much code can I execute between packets. I want to do some real time programming (velocity control, servo stuff) which adds up.
Unread 10-02-2002, 01:00
Curtis Williams Curtis Williams is offline
#0588 (Team 588)
Curtis Williams is on a distinguished road
Send a message via ICQ to Curtis Williams Send a message via AIM to Curtis Williams Send a message via MSN to Curtis Williams Send a message via Yahoo to Curtis Williams
You can get the delta_t from the master processor just like you would a joystick axis. Delta_t tells you how many packets you missed (your code was still working with a packet when a new packet came in).
Unread 10-02-2002, 09:58
Thanks. Looking at Delta_t I see that I am currently missing 1/8 packets. If I leave a subroutine out that implements a slow PWM (to get around the Victor deadband) I miss 1/16 packets. So I must be on the edge...
Now, to learn how to optimise code - pbasic style.
Any suggestions on what is good, bad and ugly with regarding pbasic coding & execution speed would be appreciated.
Cheers!
Unread 10-02-2002, 12:43
I'm not sure how you are viewing the value of delta_t, but you should realize that debug statements are really slow. Put 1 or 2 in and delta_t will go up, so your code may be fine.
Unread 10-02-2002, 16:25
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
A trick to see Delta_t easily...
The following code has the lights up just on LED at a time on the OI. For me, it is easier to see.
Joe J.
PacketsMissed VAR delta_t
' put the following just after the serin command
PacketsMissed = delta_t +1
'I know the above is sort of "unclean" code because it is not obvious that a variable on the right side of the equation is also on the left, but for me it tells me that I have changed the definition of delta_t to something more to my liking. After I have incremented delta_t, I never refer to delta_t any more, only PacketsMissed
OUTS.lowbyte = 1 << PacketsMissed
'continue with code...
Unread 10-02-2002, 19:06
THanks for the code snippet!
I had already done, logically, what you stated (look at delta T and light an LED) since, as you point out, even a trivial debug statement can easily chew up 1 cycle (9600 baud, and probably polling! - the basic stamp sure sucks)
But what I DIDN'T know, is that you can use a variable to specify which LED to illuminate. That will help make my code somewhat tighter.
Thanks!
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Autonomous code PBoss Programming 7 14-01-2003 15:29
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Operator Interface is crazee !!! HELP punarhero Programming 30 17-07-2002 14:23
