Go to Post There is a fine line between genius and insanity, watch your step! - Al Skierkiewicz [more]
Unread 01-11-2003, 20:34
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
Inertial Navigation System
Hi I was thinking about prototyping an Inertial Navigation System and was wondering what gyros and accelerometers team 190 used last year in there's and were they obtained them.
Unread 02-11-2003, 17:17
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
we are doing the same thing. According to our programmer, the program is ready, we just need some accelerometers.
I check small parts, and msc, but they are both more mechanically oriented.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 02-11-2003, 17:42
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
I know they use them in cars for measuring G-Force, so they might be with automotive things
Hows my searching? Call 1-800-Green-Dots
Unread 02-11-2003, 18:55
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Analog Devices makes some pretty cool Accelerometers and Gyroscopes.
Kevin Watson
http://kevin.org
Unread 02-11-2003, 19:25
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Blarg... a flashback from early last season...
I built an inertia navigation system, based around a Basic Stamp 2. I have the schematics and code someplace, AIM me if u want them (ExtrudedAluminiu)
The system I built was based around a three axis accelerometer and three gyros. The acellerometer and gyro outputs were integrated by op-amps (analog circuits!!) and then fed to an ADC. The BS2 would select the data it wanted, and it would read it in. It worked remarkable well on my desk. =)
I also placed a 1-axis accelerometer, and ADC, and a BS2 into a model rocket. The BS2 was supposed to read the ADC and then store the output in its onchip EEPROM. However when i tested it, the BS2 couldn't keep up with the incoming data, and I missed large enough chunks that the height that i obtained was useless.
Btw, all the accellerometers i used were from Analog Devices. They work great for projects and FIRST things.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 03-11-2003, 01:15
Rpifirst Rpifirst is offline
AKA: Nuz
#1493
Rpifirst is on a distinguished road
Send a message via AIM to Rpifirst
I know that 190 was going to write a white paper or rather we thought we should. Tommorow I will ask the lead designer of the INS about it for you. I know however that the we used a prefab mini controller along with some two axis accelerometers that I believe are normally sold in mass quanities. Also I know that it took a team of 4-5 the six week's to do altogether.
Nuz
Lambda Chi Alpha
E.H.1103
Unread 03-11-2003, 09:00
catlin101's Avatar
catlin101 catlin101 is offline
#0461 (West Side Boiler Invasion)
catlin101 will become famous soon enough
accelerometers
I did something kind of like that last year, except I did this:
I had a gyro chip, and then rotary encoders on the wheels. I was worried about using an accelerometer, because in order to get position, you need to integrate them twice. So, once the velocity gets off by a little bit, your position will start "drifting." I never actually tried using an accelerometer; maybe this isn't as big a problem as I thought.
Unread 03-11-2003, 09:18
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
You may want to check with teams 111 and 308 also.
Andy B.
Unread 03-11-2003, 09:27
AKA: Nuz
#1493
I talked to rick petty the lead designer of the ins and he said soon he will have a full website on the ins we used in 2k3 when he has it finished ill post it here.
Nuz
Lambda Chi Alpha
E.H.1103
Unread 03-11-2003, 09:39
Eric O's Avatar
Eric O Eric O is offline
AKA: Eric O'Brien
FRC #0177 (Bobcat Robotics)
Eric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond repute
Send a message via AIM to Eric O Send a message via Yahoo to Eric O
Stangs Site
You may want to check out the StangPS presentation that they have on their site if you have not checked it out yet. Here is a link to the original thread about StangPS:
http://www.chiefdelphi.com/forums/sh...hlight=stangps
Eric
Eric O'Brien
Team 177 - Bobcat Robotics (00-01,06-?)
Team 229 - Division by Zero - Clarkson University (02-05)
Unread 03-11-2003, 14:24
AKA: Allen Gregory
Weren't we only supposed to use additional electronics form digi-key or future FAI?
Unread 03-11-2003, 16:00
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Yes. Digikey sells nice microcontrollers and Future sells angular rate sensors and accelerometers by Analog Devices and other manufacturers. Between these two sources, you can get everything you need to make a nice navigation system.
Unread 03-11-2003, 16:46
AKA: Nuz
#1493
We bought both the accelerometers and microcontrolers form places other than future and digikey. I'm not really sure about the gyro it could be the one from the kit.
Nuz
Lambda Chi Alpha
E.H.1103
Unread 02-12-2003, 20:34
AKA: Allen Gregory
Re: Inertial Navigation System
Then wouldn't your robot be considered illegal.
Unread 02-12-2003, 23:23
Umm Errr...
I have some ADXL2002s (i think) lying around somewhere. They are pretty nifty and extremely sensitive.
Hint Hint: engineering samples
1139 Alumni
Electrical componenets for autonomous navigation maclaren Electrical 10 18-12-2003 02:28
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
Scoring system for 2004? DougHogg General Forum 11 16-04-2003 20:57
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
