Go to Post FIRST is the best thing that has ever happened to me...FIRST has taught me so much more than anything I learned in the classroom. The thing with my team, is we are so close, we are family, and I have figured out so much about who I am because of FIRST. - princessnatalie [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 25-10-2003, 14:26
vegasmcse's Avatar
vegasmcse vegasmcse is offline
AKA: Where'd Mark go? Polo!
#0294 (Beach Cities Robotics)
vegasmcse is an unknown quantity at this point
Unhappy How long does it take you to load the default code?
I am using a USB-Serial adapter for my laptop. It takes about 8 minutes to send down the default code to the new edu robot controller. It seems like a long time. Anyone else having the same problem?
Unread 26-10-2003, 14:57
Well, in the "did you get your edubot thread" someone said they downloaded the code in 10-15 seconds. So 8 minutes is definetly to long.
What converter are you using. What is the speed set to on it? Have you used this converter for other things?
Unread 26-10-2003, 22:25
vegasmcse's Avatar
today my son created autonomous mode
He created a full autonomous mode in the new controller and had it drive in a 4 foot triangle and then back to the center. It was pretty impressive.
When they used the team laptop that has an imbedded serial port it loaded the software in 10 seconds. I think that the adapter I have must be not integrated into the operating system properly. I attempted to modify all of the settings to change performance and nothing improved it.
Oh well
Unread 30-10-2003, 08:26
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
I'm having similar issues downloading code to the controller. Using a Belkin PDA USB-Serial (Part number R5U109) takes forever on my P4 laptop. Using my old machine with a serial port takes seconds.
Is anyone is using a USB-Serial adapter to download code that doesn't take ages? The difference is 10 seconds vs. 10 minutes. If you are, please post the manufacturer and part number.
Unread 31-10-2003, 00:27
vegasmcse's Avatar
I found a solution
The older belkin F5U103 worked great. I had even bought a new dlink DSBS25 and it didn't work either.
Unread 31-10-2003, 00:31
vegasmcse's Avatar
they are available cheap as refurbished
They are avail for 19.99 at www.belkin.com the part is F5U103rw.
Unread 02-11-2003, 10:48
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Bafo Technologies
I have a Bafo Technologies BF-810
Works great with the EDU RC.
Highly recomended.
Joe J.
Unread 03-11-2003, 01:06
Didn't we cover this last year ?
I found then that the USB -> SERIAL port adapters (probably for Macs) don't work with my WinXP laptop, but the COM port adapter does, albeit not as consistently as a good hardware COM port. Possibly, the SERIAL adapter didn't return enough (any ?) non-serial status lines, while the COM port adapter *does* simulate their return in USB, with a latency. But, there is an issue about how long it takes the adapter and the USB port to pass information back to the laptop, as mentioned in my USB->COM adapter's manual.
The algorithm for programming a single byte in a PIC calls for the programmer (hardware, perhaps the software in our case) to repeat a programming cycle of several tries, then read the just programmed byte, and then reprogram it until the byte is programmed correctly.
If the programming device can't get the feedback it needs, in time, it might just reprogram until (by chance ?) it sees the correct byte. This could be an accident of the PC's timer interrupt arriving as the PIC sends, slowing the programming logic, allowing the feedback to be perceived. In each of the bytes to be programmed, this could take forever (for instance 10 -12 minutes ?). This appears to be the case in the thread above. We'd be well advised to take a laptop with a known good hardware COM port to any competition, to avoid missing a match while reprogramming.
Unread 03-11-2003, 11:59
AKA: Dr. Joe
FRC #0088 (TJ2)
I vouch for the Bafo
I have been using the Bafo Technologies BF-810 to program Stamp2's for over a year. I have used it to program the EDU RC for a few weeks and had ZERO problems.
Go to TigerDirect.com lay down your money and forget about this problem.
Joe J.
P.S. I tried several other models with no success at all (Belkin and one other). This one works like a charm. Highly recommended.
Unread 03-11-2003, 14:39
Sounds like you got a good one, Joe.
On the other hand, it might be that your adapter works with your PC firmware, and/or the Operating system, and/or serendipity. I can hardly wait to try my adapter out on my newer, faster, laptop, with the EduKit.
Unread 03-11-2003, 21:41
AKA: Dr. Joe
FRC #0088 (TJ2)
I was too rash...
Lloyd,
You are right, I am perhaps making too strong a statement. I have only tried this unit with one PC. With the complexities of Windows, it it very likely that others will have problems with other PC's with other Firmware and BIOS's, etc. ...
But...
...I did not just randomly buy this model. I looked up the USB - Serial converter that Parallax sells on their site for the STAMP2 and then fund it for less money on the TigerDirect.com site (while I have nothing against ParallaxInc.com, I have no reason to give them an extra $3 of my money either ;-)
ParallaxInc.com USB to RS-232 conversion device:
Mfg: Bafo Technologies
Model: BF-810
Price: $22.95
TigerDirect.com USB to RS-232 conversion device:
Model: BF-810
Price: $19.99
In any case, all I can say is that it has worked great for my on the one PC I have used it on for both the STAMP2 and the EDU RC.
I wish you all the same success.
Joe J.
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
Default Robot Code lvhsrobotics Programming 2 10-01-2003 16:55
2003 PBasic default code from Innovation First ttedrow Programming 0 06-01-2003 11:18
default code archiver 2001 2 23-06-2002 22:53
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
