Go to Post You are given a goal with some simple restrictions. That's it. No one really cares how you get it done, just the fact that you get it done. - Max Lobovsky [more]
Unread 10-02-2002, 00:18
James Crivellone's Avatar
James Crivellone James Crivellone is offline
#0360 (Revolution 360°)
James Crivellone is on a distinguished road
Send a message via ICQ to James Crivellone Send a message via AIM to James Crivellone
Team 360's Robot (Sneak Peak)
James Crivellone
Team Mentor/F.I.R.S.T Event Volunteer
- Bellarmine Robotics
Unread 10-02-2002, 05:04
Jon Lawton Jon Lawton is offline
Bitter FIRST Cynic
Jon Lawton is an unknown quantity at this point
Send a message via ICQ to Jon Lawton Send a message via AIM to Jon Lawton
I still haven't quite figured out how that setup can turn, and already I want to cry. I'm fearing that in a major way.
Unread 10-02-2002, 09:28
Matt Reiland's Avatar
'The' drive behind the drive
Three steering motors!!
Wow that should steer pretty good, we will post the Pegasus pictures very soon, which drive motors are you using? Its really difficult to tell from the pics.
Unread 10-02-2002, 10:09
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Question Swerve drive?
Some how I have a strong feeling that this is a version of swerve drive. Think about it, why would they want to use three drills just to turn the wheels? The three drills are used to turn the wheels with the help of beval gears, so there could be something else that rotate the wheel box. So, all 4 wheels will spin the same speed, while some other motor steer the robot.
After all, this is just a sneak peak. The robot is probably more than just this.
Unread 10-02-2002, 15:39
Bitter FIRST Cynic
Uh... those motors don't look like they just turn the wheels! Take a closer look at the third picture. It looks like they have two gears perpindicular to eachother to transmit the force to the shaft the wheel is on. The picture is somewhat dark, so you might want to turn the contrast up.
...Or am I totally off...?
Unread 10-02-2002, 18:10
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
sorry my mistake
Unread 10-02-2002, 20:39
I am not sure why you would want all of the motors to have the same wheel speed if you needed to change the orintation of the robot. We are swerving this year with all 4 wheels interlocked but we also need to tank steer to get the orintation changed and that requires different speeds on left and right. I am not sure what the sneak peak is showing us at this point.
Unread 10-02-2002, 21:06
the front and rear wheels turn via 2 steering motors, so the front can turn independantly of the rear.
The robot is programmed to interpret wheel posistion via the X and Y on the joystick, so if u want to slide to the right, you move the joystick right, and the wheels will turn, and the robot will slide sideways, and vice versa, we can slide in any position. Pots give the robot controller information on the front and rear wheel posistion. for high speed work we have car mode, where the joystick will turn the front wheels depending on the position of the handle. If we get into a jam we have panic mode, where two knobs allow us to change the front and rear wheel position. a 3 poistion know allows us to change in between the modes, so we have 3 driving modes, depending on the drivers preference.
James Crivellone
Unread 19-02-2002, 03:31
A. Snodgrass A. Snodgrass is offline
AKA: Ashlee Snodgrass
A. Snodgrass is a splendid one to beholdA. Snodgrass is a splendid one to beholdA. Snodgrass is a splendid one to beholdA. Snodgrass is a splendid one to beholdA. Snodgrass is a splendid one to beholdA. Snodgrass is a splendid one to beholdA. Snodgrass is a splendid one to behold
very pretty james
play nice
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
Disqualifications archiver 1999 13 23-06-2002 21:53
Team 121 Sneak Peak Kyle Fenton Robot Showcase 1 09-03-2002 01:26
Team 639 sneak peak patrickrd Robot Showcase 0 12-02-2002 18:58
SNEAK PEAK (team 56 robot) Brian Savitt Robot Showcase 9 09-02-2002 07:21
