Go to Post I trust my life to a 3650 pound rolling chunk of metal every day that, if some silicon failed in just the right (wrong?) way, would splat me pretty quickly, but I have faith in engineering. On the other hand, it doesn't turn me upside down. - DonRotolo [more]
Unread 10-11-2003, 20:23
Jared Stofflett Jared Stofflett is offline
Jared Stofflett is an unknown quantity at this point
Send a message via AIM to Jared Stofflett
Programming Autonomous mode
How do you program Autonomous mode on the new controllers? I just figured I would go into the main.c file and fix it up the way I wanted it. The comments say not to edit this though, so any help on where to call the functions I write for Autonomous mode would be appreciated. In addition, how do you stop the joystick from getting input?
Unread 10-11-2003, 20:42
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
In the user_functions.c there's a part that says "INSERT YOUR OWN CODE HERE" (or something to that effect). I'm assuming that's where you insert your own code
On the other question, I believe the Programming Guide says there's no way to switch between autonomous and user modes on the EDU-Controller. (I might be wrong on that one) But you COULD make some auto. code and then upload diff code to practice driving...
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 10-11-2003, 21:34
Kel D's Avatar
Kel D Kel D is offline
FRC #0433 (Firebirds)
Kel D is just really niceKel D is just really niceKel D is just really niceKel D is just really niceKel D is just really nice
Send a message via AIM to Kel D
From what I gather the only files, or whatever they are called, that you should change are the user_routines and the user_routines_fast. The other ones shouldn't be changed.
Unread 11-11-2003, 09:32
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
I would just connect a switch to one of the digital inputs and use that to control when the bot is in "autonomous" mode vs. driver-controlled mode.
Then just use an "if" statement:
if (rc_dig_in16) {
  // Run Autonomous Code
} else {
  // Run Driver Control Code
You could put this in the Process_Data_From_Master_uP() function found in user_routines.c. If you want to keep the default drive code, put it after the call to Default_Routine(), however you could nix the default drive code by replacing that call with your new code.
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
autonomous sensor programming ? Laura_d Programming 1 10-02-2003 17:46
autonomous mode timer Don Programming 6 09-02-2003 22:16
How do you do the autonomous programming? Ryan Collings Programming 11 07-02-2003 19:38
autonomous mode? bigwalt Technical Discussion 1 21-01-2003 01:14
