Go to Post If you have a robot you don't need any more, use it for demos, or let a rookie team borrow it to learn wiring, programming, and demo around their school. - Barry Bonzack [more]
Unread 11-11-2003, 18:17
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
reworking radio control for joysticks
does anyone know if its possible to replace the thumb sticks used on most hobby radios with a more traditional FIRST style joystick?
my thought here is to bypass the internal thumbsticks on a hobby radio and wire those connections directly to the pots on a more user friendly chFlight stick.
i'm thinking of ways to take advantage of the low cost hobby radios but still give my drivers a chance to simulate controls more similar to something we might build during the regualr season.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 11-11-2003, 22:12
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
well.. you can there are just pots inside the radio, however i dont know the value of theise pots... but i am working on a white paper that may include such information that I hope to publish soon
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 12-11-2003, 11:59
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Most R/C radios these days have a provision for what is known as a "buddy" box. Usually it is a round connector something like what they used to use for a mouse or keyboard. The idea is that an inexperienced pilot can hook a friend's transmitter up to his. If he gets in trouble, just flick a switch and the buddy can take over from his own transmitter.
It should be possible to build an analog of the buddy transmitter and plug it in to the existing port. Also putting the transmitter in "buddy" mode could be a good way to figure out just what signals are required.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 18-11-2003, 23:12
The big guy
Well due to some time problems, and my computer currently dieing a slow death, it looks like the white paper wont happen any time soon...
however this site will give lots of good info on the ins and outs of most r/c radios, and if you look closely you will also see that our radios have an 7 channel encoder.. all you have to do is interface with the extra pins (unground them first btw)
http://www.rchelibase.com/radio/index.html
Justin Stiltner
KI4URQ
Unread 04-12-2003, 18:02
Umm Errr...
Re: reworking radio control for joysticks
Sure this will work. Just make sure the pots in the joysticks are the same value as the ones in the transmitter. If you need some more specifics or anything IM me post here or send me an email.
1139 Alumni
Unread 05-12-2003, 17:38
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
It is fairly easy to hook up a joystick to the buddy port. There is one problem. You will need to build a device that will convert the analog joystick signal into a PPM signal.
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
radio transmitters Arin Technical Discussion 2 18-12-2002 01:59
Ok, how much is the control system worth? archiver 2001 6 23-06-2002 22:05
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
goals: how much control? Pat Sarmiento Rules/Strategy 2 18-01-2002 19:10
