Go to Post you are going to gear that down right? Otherwise your robot will take about 10 minutes to reach its top speed of mach 2.6. - M. Hicken [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 12-11-2003, 11:31
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
EduPneumatics? Where?
I'm very sorry to have to ask this question when I have absolutely no base data (being as I haven't even had a chance to see the EduBot Package), but so be it. I haven't seen the new EduRC, nor have I seen the rest of the kit which is included in FIRST registration (however that works), but I am very interested in what anyone else might know about the pneumatics system (which is referenced various times throughout the documentation for the EduRC) which I assume is (somehow) included in the package deal. Also, I have spent a fair amout of time looking through InnovationFirst's website, to no avail. Which is not to say that I'm sure it's not there, I just have yet to find anything conclusive.
I am asking for any technical information anyone might have about the hardware associated with the EduPneumatics system, including (but not limited to) solenoid valves, actuators, pressurization system (pump, compressor, whatever you want to call it), and whatever else may be included. Pictures, in addition to written information, would be awesome, and very much appreciated.
Thanks very much in advance.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 12-11-2003, 12:10
as far as we have been able to tell, there is not 'edu pnuematics' included in the Edu kit.
There was some confusion do to a reference on the EDU solonide output being used for 'the pnuematics'
best we can figure, they mean the solonoide outputs can drive the pnumatic valves normally supplied with the competition robot kit.
so you could use the pnuematics from previous years robots, or this years (after the kickoff) with the edu bot, if you want to.
Unread 12-11-2003, 20:45
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
EDU pneumatics
The solenoid valves used in past years require 12 VDC to operate. The EDU can only run at 7.2VDC. This means that you will NOT be able to connect the solenoids used in the past to the EDU robot controller.
This does suggest that perhaps the new solenoids for the "big 'bot" might work on 7.2 VDC, but I think it most likely that we will have an "EDU pneumatics addition kit" available in the future that will work with the EDU controller.
For those interested in playing with small pneumatics systems, you might try www.gearseds.com - they make a robot kit similar to the EDU which includes pneumatics (12 VDC).
-Mr. Van
Coach, 599
Unread 12-11-2003, 23:23
Oh. That simplifies things.
Thanks again.
Unread 13-11-2003, 02:39
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Team 190 has put together an EduRobot pneumatics kit for use in the 2003 miniFIRST Competition. The kit contains two single action cylinders, two single action solenoids, a reservoir, hoses, valves, etc., and is charged with a bicycle pump. The kits ended up costing about $140 a piece from SMC.
Zan Hecht
Unread 13-11-2003, 03:04
Thanks, but I was only interested in anything that IFI would have provided.
Unread 25-11-2003, 15:22
#0599 (Robo-Dox)
EDU pneumatics
Zan-
Do you know the SMC (or other company) part numbers you used for these "kits"?
-Mr. Van
Coach, Team 599
Unread 17-03-2004, 16:04
CHS_Tommy's Avatar
CHS_Tommy CHS_Tommy is offline
#1368 (Perpetual motion)
Team Role: Driver
CHS_Tommy is on a distinguished road
Send a message via AIM to CHS_Tommy
Re: EduPneumatics? Where?
does that system run off of the 7.2 volt edu bot battery?
Raoul got 6 years for murder. He also got $10,000 for the hit. if his common-law wife spends $100 per month, how much money will he have when he gets out?
Extra credit: how much more time will he get for killing the ho that spent his money?
Unread 13-07-2004, 19:07
cvhsrobotics's Avatar
cvhsrobotics cvhsrobotics is offline
AKA: Ara K.
None #0589 (Falcon)
Team Role: Student
cvhsrobotics is an unknown quantity at this point
Send a message via AIM to cvhsrobotics
pnuematics and educations I am in!
TEAM 589~!
Crescenta Valley High School Robotics!
Unread 14-07-2004, 15:07
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
aren't the solenoid outs just 5v?
Unread 29-08-2004, 21:43
Umm Errr...
I was browsing the forums and came across this thread. I will wager a bet that we will finally see these "edu-pneumatics" in the upconing season. Lets see if my phophetic skizzles hold up.
1139 Alumni
