Go to Post Everyone is reading way too much into this. The game piece is clearly a bunch of Opahs this year. Problem solved, case closed. Start designing your fish handling robots now. - Ryan Dognaux [more]
  #31   Spotlight this post!
Unread 11-02-2002, 11:21
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
AMD is just some weird company that made a rip-off clone for cheaper.
  #32   Spotlight this post!
Unread 11-02-2002, 11:35
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Idea.....
Here's something i thought of while sitting in class...
Take a MAC computer case and put PC stuff in it or the other way around.
Purdue Alumni
Cummins, Inc.
  #33   Spotlight this post!
Unread 11-02-2002, 11:40
Greg McCoy's Avatar
boiler up!
Sounds Interesting,
What class are you in, Clark? I'm in computer apps
  #34   Spotlight this post!
Unread 11-02-2002, 13:33
Bondage's Avatar
Bondage Bondage is offline
#0116 (Epsilon Delta)
Bondage is an unknown quantity at this point
Send a message via AIM to Bondage
That cheaper rip-off clone is faster. And more durable.
<Edit> Not really me, this just happens to be my robotics hotties computer... I would be Wetzel, the guy with the funny colored car.</edit>
*landslide*
  #35   Spotlight this post!
Unread 11-02-2002, 14:31
Greg McCoy's Avatar
boiler up!
Yeah, but I think (I'm not sure) that the current AMD clock speeds are a lot lower than the current Intel clock speeds. However, the AMD processors for whatever reason seems to run faster so they turn out to run about even.
Sorry if I offended any AMD owners out there
  #36   Spotlight this post!
Unread 11-02-2002, 17:09
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Yes, Intel recently ramped up to 2.2 Ghz, while AMD has jsut released the 2000, which runs at 1.67 Ghz. The 2.2 P4A has a slightly diffrent archetecture (hence the 'A'), and doubles the L2 cache to 512KB. But the AMD chip still outperforms in Office performance as well as Linux Kernel compiling. That is efficency making up for the 32% difference in raw speed. In gaming, the new P4A has a slight edge over the Athlon XP, but is still loads more expensive. Here is a link to becnhmarks.
Tom's Hardware Benchmarks
I have an Athlon XP 1700.. It runs at 1.43 Ghz. It will outperform the Intel P4s because of the prefetch. Basicly, the data to be processed is run through a set routine. Both chips will guess ahead as to what will be needed next, and run that data. If it is found not to be needed, it is thrown out. You have wasted time. AMD not only has a better guessing ability, but it also hasa shorter pipeline, meaning that a wrong guess dosn't cost as much wasted time. So AMD went and built a much more efficent core, while Intel's Willamette (current P4 architechture) design is geared towards seeing how many transistors they can fit on the chip, thereby increasing the number Ghz. My 1.43 Ghz (actual) Athlon XP will outperform a P4 1.7 Ghz in every benchmark no sweat, everything else being equal. Intel is going away from using RAMBUS ram, which should bring the costs down somewhat, but AMD is still a better performer.
Also, by adding all those extra transistors, it generates a whole lot more heat, requireing bigger heatsink/fans and shorting the lifespan of the chip.
AMD chips are also easier to overclock, but thats an entirely diffrent matter.
Also, Cyrix made chips for a while that were really cheap, but a POS product. They stoped at the K-6II level I think...
But they were a cheap clone.
Viva Olancho!
  #37   Spotlight this post!
Unread 11-02-2002, 18:12
Greg McCoy's Avatar
boiler up!
Is "robotics hottie" an oxymoron?
Just Kidding...
Yeah, I didn't realize that AMD's had different archeticture at all. I have an Intel Pentium 4 1.5 GHz system.
It always helps to know what you're talking about before you yell
  #38   Spotlight this post!
Unread 11-02-2002, 18:21
EnderofDragon's Avatar
EnderofDragon EnderofDragon is offline
Productivity Killer
no team (Epsilon Delta)
EnderofDragon is on a distinguished road
Send a message via AIM to EnderofDragon
Almost as much as Microsoft Works
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus.
  #39   Spotlight this post!
Unread 11-02-2002, 23:26
Bondage's Avatar
oh really graham? so you don't think I'm hot? I'm incredibly insulted......*cries*
I'll chalk it up to the fact that deep down inside you're madly in love with me...
*landslide*
  #40   Spotlight this post!
Unread 14-02-2002, 16:43
Productivity Killer
How did you know!?!?!
  #41   Spotlight this post!
Unread 14-02-2002, 19:36
AntiCrombieDuck
Posts: n/a
ok im not even gonna beat u guys, i want to cry!
Want to donate too a kid 1 of those?
  #42   Spotlight this post!
Unread 14-02-2002, 22:49
Matt Attallah's Avatar
Matt Attallah Matt Attallah is offline
Now at sub 14's in a 5000lb vehicle
AKA: Maher Attallah
FRC #0005 (Robocards)
Matt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond repute
Send a message via AIM to Matt Attallah Send a message via MSN to Matt Attallah Send a message via Yahoo to Matt Attallah
768MB PC800 Rambus<--------??
How is this possable?? (I know you all love my spelling!!) I thought only way you can get that is by having 2 processors, and if that o/s can support that much. Windows only can register 512...
My Computer:
AMD Althon 1.1ghz
256 MB pc133 ram
NVIDIA 64 Pro w/ 16 mb on-chip ram
60 GB HD (7,200 I Think...)
Win XP <-----------------BBBBBOOOOOO!!!!(I Forked out the $99)
7.1 Surrond sound (yes, i did fork out some big $$ for that)
8x8x24 RW-CD-Rom
8x DVD-Rom
1.44" Floppy Drive
56K Modem
10/100 LAN Card
and dents in the side from me kicking it w/ some burn marks on the back from the power supply where the Magic Smoke came out!
That rug really tied the room together...
  #43   Spotlight this post!
Unread 14-02-2002, 23:31
Wetzel's Avatar
DC Robotics
Win XP supports more, I think up to 4 GB of RAM. (Not Sure)
Win2k supports a GB of ram.
Win9x supports 512 MB.
Linux can support more as well, I have seen Linux running with 1.5 GB Ram....
Your mobo can also limit the amount. Mine (Soyo Dragon Plust) supports only 1.5 GB of DDR ram.
Or you can get even more exotic OS's...
Viva Olancho!
  #44   Spotlight this post!
Unread 15-02-2002, 15:13
Greg McCoy's Avatar
boiler up!
Yeah, I think that's right. If you really want 4 GB of RAM, I think you can have it with XP.
  #45   Spotlight this post!
Unread 24-02-2002, 02:53
Wetzel's Avatar
DC Robotics
w00t!
Have secured funds for a duile board and another XP 1700.
Next, go to my local computer store and purchase said items.
Thirdly, browrow 512mg ram from a friend, to total a gig in machine.
Then see how fast 3dMax will render.
Viva Olancho!
My computer loves Microsoft ARGH!! HELP ME! team222badbrad Chit-Chat 12 29-01-2005 09:17
Best computer brand kewlkid382 Chit-Chat 22 05-03-2003 18:32
List of UTC Hartford Teams archiver 2001 3 24-06-2002 01:09
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
My other computer will not work with this forum! David Kelso CD Forum Support 4 04-06-2001 21:52
