Go to Post Legend has it that Brandon installs the server in a bulletproof case shortly before Kickoff. That way, when the server explodes, the damage to surrounding things is minimal. - Billfred [more]
Unread 12-11-2003, 16:01
AlphaOmega870 AlphaOmega870 is offline
AKA: Mike
#0870 (Southold RICE)
AlphaOmega870 is an unknown quantity at this point
Send a message via AIM to AlphaOmega870
EDU Robots
could someone post a code for the edu robots to test the r/c. Please not the sample program.
Unread 12-11-2003, 17:29
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
hmmm is 870 also named Alpha Omega?
Unread 13-11-2003, 09:07
if you want something other than the default (sample) code
then what do you want the test code to do? what functions do you want it to preform?
the default code is pretty straightforward for testing out the EDU controller - each joystick (PWM) input maps to one of the PWM outputs, so you can put a servo on pwm1 and wiggle it with the joystick, move it to pwm2 and control it with a different joystick axis...
what other sort of test do you want?
Unread 13-11-2003, 10:27
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
In the programming white papers on this site there is a program that you can use to send commands to the EDUbot from a PC. Unzip the archive and run setup.exe to install the program. There will be a .hex file in the same folder where you tell the setup program to install the application. Download the .hex file to the RC using the IFI loader. Start the EDUController app, it will be available on the Start menu. Select the COM port you're using and hit the "Open" button. The joysticks on the left-hand side map to the PWM_in inputs. The feedback bytes map to the PWM outputs. As you move the joysticks around you should see the PWM outputs change accordingly.
If you want to wait until tomorrow I'll post an updated version sometime tonight. I added a byte of digital inputs and am working on a data logging/plotting function. I'll include the VB source so you can do whatever you want with it. Eventually I want to add DirectX support to bind joysticks, but I don't know if I'll be able to finish tonight.
FYI: FIRST Robots at the NYC Hall of Science Rich Wong General Forum 9 11-07-2002 10:52
Does anyone have stats about robots falling over? archiver 2001 8 24-06-2002 02:45
how effective do you think robots going under the bar archiver 2001 4 24-06-2002 00:36
What about prettiest robots? archiver 2000 8 23-06-2002 23:09
'Accidently' ripping other robots apart Vipersna Rumor Mill 6 04-01-2002 23:27
