Go to Post This is a game folks, and rules are rules, even if you kinda sorta broke one rule in the end its still broken - Mike Schroeder [more]
Unread 13-11-2003, 17:15
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
I guess it mostly comes down to your design/strategy. The geometry of Bosch and 8020 has certain strength benefits over standard structural extruded aluminum. However, if you don't plan on doing a whole lot of crashing and banging, and have the facilities and the manpower (experience), I'd use welded aluminum structural extrusion (either angle, channel, or possibly even square).
Steel is far too heavy and difficult to cut. I don't believe it's worth the weight versus the benefits for use in structural members. Bosch/8020 does have a certain ease-of-use factor to benefit, but if you support your frame correctly, you shouldn't need to ever take your frame apart to fix a broken/bent extrusion. Use cross-beams to support other extrusions and disperse impact energy accross your entire frame and you should be fine.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Rendering Tips Tyler Olds 3D Animation and Competition 27 16-10-2003 01:32
Impending BASIC Stamp Editor Beta 2 release Greg Ross Programming 9 19-09-2003 06:05
Basic Run Error BBFIRSTCHICK Programming 10 02-04-2003 22:43
Auxilliary Basic Stamp Chip Kai Zhao Technical Discussion 9 07-01-2003 21:21
Additional allowed materials kmcclary Off-Season Events 3 11-10-2001 13:05
