Go to Post Go with what you know will work, and try a little less if you are feeling brave. That is my rule of thumb. - sanddrag [more]
Unread 19-11-2003, 06:37
edomus's Avatar
edomus edomus is offline
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
edomus is on a distinguished road
Send a message via AIM to edomus
sensors
will infared sensors work through glass? and can they be programmed to perform a function only after activated for a certain time, say 3 seconds?
2004 National Finalists with 469 and 868
2004 Gallileo champions and #1 seed
  • Delphi "Driving tommarows technology" -philly 2004
  • 8th seed philly 2004
  • 58/58 at annapolis 2004 (like the improvement?)
  • Philadelphia Alliance Regional Winner!-2003
  • 7th seed Philly 2003
  • Rookie all star philly 2003
  • semi finalist Pitt 2003
  • picked 3rd in pitt 2003
  • Seeded 17(curie) at nats 2003
Unread 19-11-2003, 08:56
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
What kind of infrared sensors are you using? The sensors don't do anything on their own, they just measure a value and let you know what it is. Its up to you to take that information and do something useful with it.
Unread 19-11-2003, 10:46
skrussel skrussel is offline
no team (000)
skrussel has a spectacular aura aboutskrussel has a spectacular aura aboutskrussel has a spectacular aura about
Infrared through glass
Not sure - [I know that UV doesn't go through glass]
But here's a way to check: Try it (under power) through the glass you plan to use, and if the light comes on, then you know it can .......if it doesn't, why not just drill a hole through the glass where you place the sensor.
(Info came from Bob Koehl, engineer on Team Ford FIRST)
Unread 19-11-2003, 13:39
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
IR LED's can be seen on a CamCorder
If you are trying to debug IR stuff, there is nothing so useful as a camcorder.
The CCD sensors are sensitive to infrared frequencies.
Try it. It works.
Joe J.
Unread 19-11-2003, 14:39
IR will go through glass
it will also go through black electrical tape (its transparent to IR)
Unread 19-11-2003, 16:46
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
If you are trying to debug IR stuff, there is nothing so useful as a camcorder. The CCD sensors are sensitive to infrared frequencies.
I know. Infared should pop up as a purplish haze on a digital camera.
Electrical tape on the floor will work. I have seen plenty of line following robots follow a line of electrical tape. In fact read all the way to the bottom of the webpage.
sensor
Robotics Tournament at Sensors Expo & Conference Kyle Fenton Off-Season Events 4 04-05-2003 12:15
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
Robogui ! sensors don't work Fares Programming 2 07-01-2003 16:31
pre-built autonomous sensors? BandChick Technical Discussion 4 05-01-2003 22:06
