Go to Post I hope there are people in this world who love you too much to let you mentor while you are in college - PayneTrain [more]
Unread 18-11-2003, 23:33
edomus's Avatar
edomus edomus is offline
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
edomus is on a distinguished road
Send a message via AIM to edomus
Air ship
An adult friend of mine came to me yesterday and asked if I could figure out a controll mechanism for an "airship" that he has been working on for 3 years. Would it be wise to use FIRST issue equipment? What other processors and controll mechanisms are available for completely home made RC's. any input would be apreciated.
2004 National Finalists with 469 and 868
2004 Gallileo champions and #1 seed
  • Delphi "Driving tommarows technology" -philly 2004
  • 8th seed philly 2004
  • 58/58 at annapolis 2004 (like the improvement?)
  • Philadelphia Alliance Regional Winner!-2003
  • 7th seed Philly 2003
  • Rookie all star philly 2003
  • semi finalist Pitt 2003
  • picked 3rd in pitt 2003
  • Seeded 17(curie) at nats 2003
Unread 18-11-2003, 23:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I take it this is a radio controlled unmanned air ship. How big is it and what powers it? Any pics?
Unread 19-11-2003, 11:02
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
The first question is "what is the lifting capacity?". If it has been worked on for three years, there should be some idea what this number is. Obviously you don't want a control system whose weight is higher than this number.
FIRST stuff is rather heavy in relation to the R/C stuff on the market today. It is also overkill for the application, unless he wants to do pre-programmed manouvers or program it to avoid walls or something else that requires programming.
The R/C gear used for handlaunch sailplanes weighs a few ounces. In this application, the weight could be further reduced by removing the cases for the reciever and parts of the servo cases. These are designed to survive high velocity impacts with the ground. This is not something you need to worry about with an airship. Even if the bag should have a catastrophic failure, there should be enough area that it kind of floats down. So the gear should be recoverable in any case.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 19-11-2003, 11:12
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
whatever you do......
dont let this happen
Unread 19-11-2003, 11:13
That is why we now use helium instead of hydrogen.
Unread 19-11-2003, 18:17
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Re: Air ship
No. IFI controllers are way heavier than they need to be.
You could buy a much lighter controller with nearly the same features. I would also suggest a lighter battery. But the same type of electronics should be fine, and you have experience in them.
(i'm talking about the old controllers, not our nice new ones.)
Of course, If I were building an airship, i would totally use hydrogen, i mean, if its unmanned who really cares if it explodes? Hydrogen will weigh about half what helium does, and therefore you get added lift! Not twice the lift, but a little more, and thats what counts.
Heh, an hydrogen isn't THAT dangerous . . i fed a test-tube full to a candle once (result of electrolosys) and all it did was make a flash and a whooshing noise . . .
so in R/C airship quantities, it should be relatively safe . . . as long as you don't TRY to burn it or anything.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Where to get air muslce pneumatics? Adam Y. Pneumatics 5 27-12-2003 23:17
What are pneumatics? Aignam Pneumatics 23 16-10-2002 21:17
ship date in the documentation archiver 2001 3 24-06-2002 00:01
Player Station...to ship or not to ship? archiver 2000 1 23-06-2002 23:13
Air Fare to Florida archiver 2000 0 23-06-2002 22:16
