Go to Post Just call me conservative. - dlavery [more]
Unread 20-11-2003, 08:50
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Powdered Metal Filter Material
There are 100's maybe 1000's of powdered metal filtration media sources.
Seach with google you will find many many sources. I have one such search result linked to below.
I hope this helps.
Joe J.
One PM Filter source
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
Using a switch before autonomous operation KZos550 Programming 11 04-02-2003 19:12
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
