White Paper Discuss: Using an Operator Interface with the 2004 EDU RC
Thread created automatically to discuss a document in the White Papers.
Using an Operator Interface with the 2004 EDU RC by Dave Flowerday |
Cool idea
I really like this idea. Nice job.
Concerning power to both EDU RC's, I propose switching right now to hobbyist batteries and chargers. We have made a small harness that goes from the EDU RC's battery plug to a plug that a standard hobbyist (Remote Control RC) battery can plug into. There are a lot of reasons this is a good idea but the main ones are #1 Typical RC batteries are cheaper and have larger capacity (1800mAHours are pretty standard, 2400mAHour versions available) than Innovation First batteries AND # 2 RC chargers are faster, cheaper and better than the Innovation First chargers (and also can run off of a 12V battery, which means we can charge the EDU batteries using a standard FIRST battery -- no AC required!). Given this white paper, we will probably make a Y connector to power both EDU RC from a single RC battery. Joe J. Last edited by Joe Johnson : 20-11-2003 at 13:29. |
Re: Cool idea
Tower Hobby has them...
Link to Tower Hobby Page w/Connectors
I purchased some from TowerHobby.com but I cannot lay my hands on the paperwork just now. I am 95% that it is one the female* from the set I have linked to But... ...There is that last 5% ;-) You can also buy the battery, charger and mating connector for the batteries from Tower as well. Hope this helps. Joe J. P.S. Be careful ordering Male and Female connectors from Tower Hobby. They typically refer to the sex of the plastic connector when they refer to male and female. In the auto industry we always refer to the sex of the TERMINAL (which is almost always opposite of the sex of the plastic housing so you can order the wronp part pretty easily -- actually, looking at the picture from the Tower Hobby sight, I THINK the picture has the terminals paired up Male-Male and Female-Female... ...I could make a MA joke here but it is too easy... ;-) Last edited by Joe Johnson : 20-11-2003 at 17:28. |
Re: Re: Cool idea
Connectors
I am using R/C connectors from Radio Shack. I modiifed the corners to allow entry into the Edu connector.
We powered up our 2003 robot last night and had a splendid display of the need to debug. The shifting switch turned the beacon off and on and the air pump never shut off just for starters. We will be running around after Thanksgiving! |
#7
Re: Connectors
Hey.
Thanks alot for this code. We finally decided to put it to good use on a prototype bot. To power the second controller we just used 6 Nickel Metal Hydride rechargeable batteries (1.2 volts each * 6 = 7.2 volts), and some alligator clips to connect them to the terminals... Its a little shaky but it works. One thing I would like to add that we overlooked and spent a half an hour diagnosing is that the switch on the 2003 EDURC needs to be switched to "Program." Its very easy to overlook. Otherwise the code and setup works great! Thanks alot Dave! |
| White Paper Discuss: Drive Train Basics | CD47-Bot | Extra Discussion | 6 | 06-09-2012 11:42 |
| White Paper Discuss: FIRST Motors, Etc. | CD47-Bot | Extra Discussion | 1 | 16-10-2003 09:14 |
| White Paper Discuss: FIRST Editor v1.2 Source | CD47-Bot | Extra Discussion | 1 | 18-09-2003 19:34 |
| White Paper Discuss: FIRST Editor v1.2 | CD47-Bot | Extra Discussion | 1 | 18-09-2003 19:32 |
