Go to Post The robot competition is the most obvious, visible, and distilled-media-friendly part of the picture... We shouldn't be surprised that it's all that gets into the news coverage, when that coverage is managed by someone who isn't already well versed in what FIRST is trying to do. - Alan Anderson [more]
Unread 20-11-2003, 16:14
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
White Paper Discuss: Standard Drive Photos
Thread created automatically to discuss a document in the White Papers.
Standard Drive Photos by Sachiel7
Unread 20-11-2003, 16:18
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
In these pics, you have the left and right wheels running on the same axle. If the two wheels were connected they would have to be spinning in the same direction, which would make it impossible to turn.
Unread 20-11-2003, 16:43
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
i believe that he has bearings in the wheel, and the sprockets are bolted on to the wheel.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 20-11-2003, 18:12
It's a Bird
AKA: BoogyShoes
Ok I can see that, but then why is is the axle in a bearing? Either way, you don't need an axle running the length of the robot. Its just wasted weight, and space.
Unread 20-11-2003, 19:08
RogerR's Avatar
AKA: Roger Riquelme
i'm not sure why for that one.
there are two possible reasons that i can see for this:
1) there is no frame outside of the wheels, so if you used two independant axles, they would only be supported at one point, and the wheels (and more importantly, the sprockets) would be more vulnerable to becoming misaligned.
2) in addition to this, if the axles are beefy enough, they could be used to reinforce the chasis of the robot.
Unread 20-11-2003, 20:00
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Yes, the wheels are on bearings, and the sprockets are mounted onto them. I have had sooooooooo many people skip this possibility and post "it can't turn" it's not funny. So don't worry, your'e definitely not the first .
The axles run through the chassis for reinforcement, and yes there is no frame beyond the wheels (unless you count a plexi-cover a barrier ). The bearings both bolt the frame together (they're 4-bolt flange bearings) and support all the drive axles. In pic 2( I think) there is a closeup of one corner of the frame. (BTW, the bars are 1" aluminum bar extrusion (hollow)) There are 2 pieces of angle holding the edges together. The inside is 1.5x1.5" and the outside is 2.5x2.5" (The extra inch is for the length of the chassis bars).
A bolt runs through each bar from one angle to the next, and a large bolt goes down from the top of the corner through all 4 to the base. This alone in every corner wouln't hold the frame too well, it would hold, but the frame would probably begin to get bent, or fall apart after a while.
So, I added the flanged bearings to bolt the top and bottom sidebars together. This helps (along with the axles) to reinforce and keep it held together properly.
It sounds like we are planning on using this design next year (04), instead of the MultiDrive I designed.
This system actually worked great last year. While our frame was different, the drive setup was 80% the same. We were the fastest at our regional, and we had no problems winning a pushing bout.
The idea was to come up with an improvement to last year's design. A slightly lighter yet stronger frame, easier construction, cheaper cost, etc. I think I've captured all of that.
It was also necessary that it would require less modifying of parts, and more putting things together, thus more of an emphasis on bolting than cutting pieces, etc.
We (in all confidence) also have boldly claimed that we can build it and have it running in one day. I think we can accomplish this goal.
We're taking advantage of pre-design here. Coming up with things that can be designed pre-season and going through them.
At our December meeting (not too long from now) we plan to have a vote for our drive system. It's NOT a definite vote, the vote is "we'll use this unless there's a good reason not to". That way, we can have our drive/chassis defined the day of kickoff, and order the parts. Within the first week, we'll have a driving chassis complete, with 5 weeks to go. I've only heard of a few cases of that occurring. And, it helps.
Anyway....This was just an example for people to show their new folks an example of a not too complicated drive. Hope It helps.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
White Paper Discuss: Drive Train Basics CD47-Bot Extra Discussion 6 06-09-2012 11:42
Some code in C that we may need if we are in trouble Andrew Rudolph Chit-Chat 16 07-10-2003 21:34
White Paper Discuss: FIRST Editor (v1.1) CD47-Bot Extra Discussion 7 17-09-2003 19:07
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 03-09-2003 10:40
White Paper Discuss: Pocket PC 2002 Scoring Program CD47-Bot Extra Discussion 3 16-01-2003 09:45
