Go to Post This was my freshman year, and I can't wait for next year! - Éowyn [more]
Unread 20-11-2003, 05:58
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
switch lever exhaust
I'm working on patent for an air filter that I designed during my freshman year at Drexel. I'd tell you more but you'd steal it,
I am looking for a material that air can pass through easily, but light cannot. I have thought of either AC filters (I'm not sure if they're opaque enought, though) and this stuff at work.
At work, there is a pneumatic system setup for switching between rails, etc. (details not important) On the switch levers, or whatever you call them, the levers used to actuate the cylinder, there is an exhaust. The exhaust is covered (to protect it from foreign objects) by a hard white foam-like material.
I'm sorry I don't know the proper terminology, but does anyone know what I'm refering to? Does anyone know what this foam like material is?
I'll bring my digital camera to work tomarrow and get a picture of it, to clarify for you.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 20-11-2003, 08:50
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Powdered Metal Filter Material
There are 100's maybe 1000's of powdered metal filtration media sources.
Seach with google you will find many many sources. I have one such search result linked to below.
I hope this helps.
Joe J.
One PM Filter source
Unread 20-11-2003, 09:09
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Most LIkely the White bit you see is an muffler for the air comming out, they are avaliable in mcmaster, and possably in the size you may need.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 20-11-2003, 16:40
Umm Errr...
I have a pnumatic air filter, which uses that stuff. Its also in the end of alot of pen ink cartridges(i think its the same stuff).
1139 Alumni
Unread 21-11-2003, 06:54
as promised here are the pictures. The part I'm referring to with a very eye pleasing arrow pointing to my dilemma.
155, teacher: 2011-
Unread 21-11-2003, 06:56
and the good stuff
155, teacher: 2011-
Unread 03-12-2003, 10:24
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Cool Re: switch lever exhaust
i would put a train whistle on the exhaust ports That would be so P.I.M.P.
Unread 06-12-2003, 13:02
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Here's what you are looking for:
SMC: AN[ ]03 Series Mufflers, specifically from your picture, AN203 (See Page 2)
The material is "PP Sintered", or Sintered Polypropylene
http://www.smcusa.com/CC_catalogs_31...ea/AN_6009.pdf
Unread 07-12-2003, 07:14
Thanks. I went to the site and found info about the lever, but didn't realize that there was that silencer on it. Thanks again.
155, teacher: 2011-
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
Using a switch before autonomous operation KZos550 Programming 11 04-02-2003 19:12
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
