Go to Post Hey that was easy, we settled the argument on CD in one post! :^) - KenWittlief [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 21-11-2003, 13:52
Tim Skloss's Avatar
Tim Skloss Tim Skloss is offline
Dr. Skloss
FRC #0930
Team Role: Parent
Tim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the rough
Exclamation How to connect the R/C receiver?!
Where does one find PWM leads with the proper, UNSHROUDED connector that can plug into the new EduBot controller? We are looking for 3 inch leads with unshrouded pins.
All the hobby stores in town and on the internet (Tower, Horizon, Lobby, etc.) only sell the wires with shrouds around the pins. The shrouds keep you from plugging into the Edubot!
Only Innovation FIRST seems to have these leads, but we don't want to put six 24 inch-long leads on the Edubot just to connect to the receiver!
If money was not a problem, we would buy micro receivers which have the PWM pins prodruding past the receiver housing. That way we could plug the receiver directly into the EduBot controller.
But money is tight... and we are all VERY DISSAPPOINTED in FIRST that they required us to go out and buy an expensive R/C radio without warning! The best deal we have found is for the Tower Hobbies 6 channel FM kit without servos for $99. But we still need the leads!
Now only a bit of the Edubot (software) is like the real robot.
FIRST Mentor and Team Leader
C.O.R.E 2062 a NASA, GE Volunteers and Rockwell Automation FRC Team
Unread 21-11-2003, 14:28
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
If you're not a rookie team you can hook up last year's EDU to this year's EDU and use the IFI OI. More info is at http://www.chiefdelphi.com/forums/pa...le&paperid=245
Unread 21-11-2003, 14:46
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
The shrouds actually come off fairly easily. The ones I've seen are typically just held on by friction (and maybe some reall light glue). So you can just pull the shroud right off.(Of if that fails, you can very easily cut the shroud).
[EDIT] Or look here: http://www.chiefdelphi.com/forums/sh...threadid=22798
[/EDIT]
On a side note: Why do you say "Now only a bit of the Edubot (software) is like the real robot."
You should be able to bascially copy your UserRoutines.c from one to the other with only a few minor changes (such as there being not PWM_inXX on the full size).. Beyond that the values you get from the Full Size OI Joysticks should be the same as the ones from the RC controller (though the RC controller may have a more limited range, YMMV).
If you need clarification on what I just said, feel free to ask..
Unread 22-11-2003, 22:42
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
I belive that the lead type used by IFI is hitec/JR style connectors
from tower hobbies you would need to look for an alerion extension it is the lead that you would need.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 24-11-2003, 16:52
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
In a pinch you can use 0.1" breakaway headers. Cut the connector off, solder and shrink wrap the leads to the pins.
Unread 04-12-2003, 18:07
Tim Skloss's Avatar
Dr. Skloss
FRC #0930
Team Role: Parent
Talking Re: How to connect the R/C receiver?!
Found a FIX!
Look at the attached jpeg for a pictorial view. I purchased Futaba J-type extensions from Tower Hobbies (the Hobbico brand is cheaper). These have the shroud around the pins molded into the connector.
[Older extensions have a box-like second piece that's snapped over the connector with pins. You can just pull the box off with two pairs of pliers--one to hold the connector and one to grab the shroud.]
First, carefully remove the wires by prying up the black tab with a small regular screwdriver. If you pull on the wire while you lift the tab, the wire will release more easily. Cut off the extension piece of the shroud using a suitable tool. I used a paper cutter shear. Then simply plug the wires back in and you are done! I got great results!!!
Unread 04-12-2003, 18:57
Umm Errr...
One of the biggest problems with IFI stuff are those evil unshrouded pin headers from which the connectors fall out. I would have though IFI woulf have fixed this, as historically the PWM connectors have been liek the #1 cause of electrical probs. I like the solution above. I would have just cur the shroud off.
1139 Alumni
Unread 10-12-2003, 16:34
InnovationFirst's Avatar
InnovationFirst InnovationFirst is offline
Official FIRST Supplier
InnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond repute
Innovation First has 6" PWM cables made to link the EDU RC to an R/C Receiver. They do not have shrouds.
http://www.innovationfirst.com/FIRST...electrical.htm
FIRST College Connect is now UP!!!! Erin Rapacki General Forum 30 29-06-2007 11:25
EDU R/C Based Robot Venkatesh Technical Discussion 2 02-12-2003 15:20
R/C Control types Andy Brockway Programming 43 24-11-2003 17:07
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
Need info on how to build temp. receiver and transmitter archiver 1999 5 23-06-2002 22:01
