Go to Post Team newb: To expect any average group of high schoolers to build and develop a robot in less than six weeks is...madness! Me: Madness? THIS IS FIRST! - MishraArtificer [more]
Unread 21-11-2003, 16:16
in an automatic transmission like this in a car, there are clutch mechanisms, called bands, that hold one set of gears still, to get the ratio you want to the output
and dont forget, the torque converter in a car is not only a slipping clutch, it is also a form of hydralic CVT itself (its like a backwards CVT - the motor can vary over a range of rpms while the drive wheels are at a constant speed)
You can get more HP out of an automatic transmission off the line, than you can from a standard one (with a clutch) because the auto can rev up to its optimum RPM
very similar to the problem we face with electic motors - to get the most HP they have to be spinning at the midpoint of their RPM range
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
I²C Interface on PIC CBM3 Programming 2 01-11-2003 22:28
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
FYI 'Image Discuss:' is now 'Pic:' Brandon Martus Announcements 0 24-02-2003 12:17
