Go to Post Even then, the robotics competiton is only part of FIRST. - Billfred [more]
Unread 21-11-2003, 17:41
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Yeah, those casters should work pretty good. They don't look like your typical drag casters. The further away from the pivot point the wheel is, the more likely you are to have turning problems. Those look pretty central.
My question is this though:
If you went down to 1 caster in the center of your front and made your back the front(the drive wheels), do you think It'd turn less anonymously? I personally didn't get to see sparky too much, but it did seem to be swerving around alot during the time I watched it. I'm not sure if that was intentional though.
Anyway, If it worked good, then great, there should be no problem. I also like what 422 did this year for front casters. They look two large (6x6x6"?) blocks of the HDPE material(or something like it) and lathed it down to half a sphere. They threaded through the center of the flat side and bolted them at the front corners of their bot. It worked great.
When it comes down to it, the casters function is simply to support the frame. If it's causing your bot to shift around, it's not serving it's purpose correctly, and needs fixing.
In the summer of 02 we modded up our bot for the MD state fair. When I got up there I found that they mounted 2 casters in the front with 2 rear drive wheels. It was a mess. It took me 2 days (and 4 hours of fixing programming after a new member 'tinkered' with it) to convince them to flip the bot so the back was the front and they had a center caster in the rear. All this was done on one joystick. It worked great after they finally let me try it.
What would be a really good steal is if you can get the casters where the wheel is a sphere, and the pivot point is directly over the wheel. This way, you don't need to worry about odd shifting.
Anyway, with the casters you have there I can see why you wouldn't have as much trouble, but a typical rookie team wouln't necessarily think of that. Just keep that in mind...
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
White Paper Discuss: Drive Train Basics CD47-Bot Extra Discussion 6 06-09-2012 11:42
2 Gear Drive Train AT man General Forum 31 12-02-2003 19:05
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
Another chapter in the drive train story AdamT Technical Discussion 19 29-09-2002 13:52
Blowing fuses/tuning drive train DougHogg Motors 10 23-06-2002 00:24
