Go to Post Why not go the safer route? Use the robots to play Magic the Gathering. - kamocat [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 21-11-2003, 09:12
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Part numbers for EDU accessories
I think that more people will be trying to find the right connectors and components for the EDUbot as they start using them. I'd like to start a list of specific vendors and part numbers for basic stuff. Heres a start:
CONNECTORS FOR EDU-RC INPUTS:
**Digital and analog, NOT PWM!
3-conductor housings: jameco.com, part number 157382, $0.24
crimp pins: jameco.com, part number 100765, $0.09
I use the cheap crimper from Radio Shack and a tiny dab of solder. http://www.radioshack.com/product.as...%5Fid=276-1595
SHARP PROXIMITY SENSORS:
GP2D120, 1" - 12" range, acroname.com, $12.50
GP2Y0A02YK, 8" - 5' range, acroname.com, $15.00
Connectors, acroname.com, $2.00 for a pack of 3
You can get these from digi-key as well, but they don't sell the connectors.
VISIBLE LIGHT PHOTOTRANSISTOR:
With integrated lens, jameco.com, part number 120221, $1.95
They are similar to a photoresistor except they have a faster response time and a built-in lens so you don't need to shrink wrap it. Adding an LED pointing downwards will make it easier for a line-following application.
1) Snip off the base lead
2) Connect the collector lead to +5 from RC input pin
3) Connect a 10k resistor or pot to the emitter lead
4) Connect the resistor to the GND RC input pin
5) Connect the RC input between the emitter and resistor
You can vary the sensitivity by changing the resistor value. The input will be analog, where higher values are lighter colors (or brighter light source). I would build it on a breadboard and find the best resistor value for your application before making it permanent.
Unread 22-11-2003, 15:32
Umm Errr...
Hmm sharp sensors. Im building an edubot wanderer with some of those. Maybie i'll post a whitepaper with cade etc when i'm done.
1139 Alumni
pneumatic cylinder part numbers Ed Crammond Pneumatics 0 14-02-2003 19:27
Can I reduce the number of similar part files? roknjohn Inventor 2 29-01-2003 21:36
Spec Sheets on FIRST Website! Raul Kit & Additional Hardware 2 15-01-2003 15:45
A couple of noodle scratchers Cheese Head Programming 11 07-12-2002 09:59
Even more interesting numbers: Division of regional winners archiver 2001 8 24-06-2002 03:10
