Go to Post We build because we can. - Danaca [more]
Unread 26-01-2002, 14:22
Nuts4FIRST Nuts4FIRST is offline
no team ("Independent FIRST Advocate")
Nuts4FIRST is an unknown quantity at this point
What is the wiring for the FESTO valve?
What is the wiring for the FESTO high speed single selenoid valve?
It has three wires: Black, Purple, and Brown. I have tried connecting these wires in various combintations to a battery and haven't been able to get the poppet to move.
I'm under the assumption that they work similary to the two wire SMC values. When I connect these wires to a battery I can hear the poppet move.
Thanks,
Chris
Unread 26-01-2002, 17:03
My team found after playing with it, that the black wire isn't necessary. Use the other two wires like you would the other solenoids.
Unread 11-02-2002, 19:29
Khalicl13 Khalicl13 is offline
#0486 (The Positronic Panthers)
Khalicl13 is an unknown quantity at this point
Send a message via AIM to Khalicl13 Send a message via Yahoo to Khalicl13
When we powered our FESTO, I heard the poppet move but there was no change in airflow. Any advice?
Khalid Harun, Student Project Manager, Programmer, Webmaster
Team 486 - The Positronic Panthers
www.positronicpanther.com
_Khalid_13@yahoo.com
Unread 12-02-2002, 08:49
With the silicone coated circuit board in place, the little LEDs light when power is coming through.
If you hear a click while adequate pressure is applied to the pressure port, flow should change.
If you are using your lungs to provide the pressure, it won't work - pressure too low
If your robot system is providing pressure, and you are checking operation with no load connected to the valve ports, the pressure you can get is still too low.
Without cylinders attatched, use some kind of flow control - either the grey flow control valves on the end of some tubing (not in the ports of the FESTO), or just kink the tubing in a 180 degree bend. then operate the FESTO valve, and see if the air goes the other way, by slowly releasing the tubing.
If it doesn't, contact FESTO.
Unread 12-02-2002, 17:14
thnx
Festo valve.... why wont it work? CHSguard72 Pneumatics 3 08-02-2003 19:07
trouble with assembling FESTO valve geo Pneumatics 15 02-02-2003 09:28
Link to Festo Valve Assembly Info Scott358 Pneumatics 0 04-01-2003 17:17
Dismantle Solenoid valve? archiver 2001 2 23-06-2002 23:34
Festo Valve Gary Bonner Pneumatics 2 26-02-2002 17:48
