Go to Post In the end, we were successful, but the tale is one of such stupidity that it should be engraved in drool upon a failed math test. - AmLameBro [more]
Unread 24-11-2003, 01:50
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
White Paper Discuss: EDU Robot Controller PC Interface
Thread created automatically to discuss a document in the White Papers.
EDU Robot Controller PC Interface by seanwitte
Unread 24-11-2003, 01:55
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Cool
This is a really good program!
It not only serves as a new method of input for those of us with low resources, but it also gives great programming examples of serial communication! Great job!
I would only have to recommend one addition to the program:
-Reading joystick input
I think if the PC could pull the input from at least one Joystick and assign it to step in for one of the four joystick inputs, that'd be great. Since this is a windows app, you should be able to use the Windows API for joysticks without worrying about the system's setup. We could actually drive the edu around with a joystick on our pc! The mouse kinda gets tricky after a while
I'm actually going to try and write a small piece of code to do that now, using what you've put up here. Then I can work on writing a port of my CopyCat code for the new controller!!! YEAH!!
Once again, GREAT JOB!
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 24-11-2003, 08:33
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
That program is just a prototyping tool. I received a request to add joystick support but just haven't had time to do it. I have added a data capture feature so that you can capture and plot up to 10 of the IO values. The printing is flakey but you can save a capture plot as a bitmap. Will post it once its been confirmed that it works. I'm out of town for the holidays so one of the other engineers has the controller.
BTW - If you right-click on the joystick it recenters both axis.
Unread 24-11-2003, 09:34
Sachiel7's Avatar
AKA: Shayne Helms
Sounds cool.
Heh, I just figured that out last night. Helps alot!
I have a few questions though:
What did you use to program this?
I'm trying to understand the communications a bit more. I don't have very much experience in serial or COM communications at all. From what I understand, the PC puts together a data packet of all 4 joysticks. This is 8 bytes in length. I'm assuming it's 2 bytes per joystick, 1 byte per axis. When Its got a new packet ready, it sends out a signal to the RC. When the RC is ready to receive, it sends a signal back. The RC receives the packet, then sends out its 10 byte, 2 integer packet back.
But I'm having trouble with the inner workings of this routine. I browsed through the pc_interface.c file included in the packet, and found the Wait4TXEmpty function call. I noticed that when I tried to compile the project, I couldn't, because the alias.h was referred to as IFI_aliases.h and the IFI_default.h (i think) was missing something. I'm guessing you updated the default code with that function.
Anyway, I'm guessing that it means wait until the PC has pulled this value.
So, when I load up my program (the one I wrote for the joysticks ) and it starts transmitting data, the RC gets stuck in an infinite loop. Now, my PC recognizes if the RC goes offline, so I know it's seeing it right. I just don't think I'm handling everything correctly. Could you give a C code example (even though I'm using Qbasic ...for now...) of how the data's put together and sent/received. Anyway, I have got the joystick input working aok. I've got one flight stick hooked up, and I can pull all the axis, wheel, and buttons from it. The program I have currently calibrates the joystick at startup, then filers the values every cycle, so they range from 0-254, and the axis are lined up correctly. So far so good. I just need an idea of what to do after that. After 1 PC cycle, the next packet is ready. So, I'm supposed to send a small byte to the RC, right? Or do I pull a value?
That's where most of my confusion sets in.
Oh, and another quick question:
What's the setup of the COM connection?
9600baud, no parity, 7 databits, 1 stopbit ?
That also may be where I'm off. Anyway, thank's for the help.
-=Sachiel7=-
Unread 24-11-2003, 10:01
None #0116
The sequence is as follows:
1. PC sends 1 arbitrary byte to tell the RC to get ready to receive.
2. RC sends back 1 byte and waits for 8 bytes in the receive buffer.
3. RC sends its data packet back.
The baud rate matches the default that IFI uses, which is 19200, 8 bits, no parity, one stop bit.
Write your PC client so that it reads the joystick and sends one byte to the RC. On the RC side, just grab the value in the recieve buffer whenever data is waiting and write it to a PWM output with a servo attached. Once you get that working add the rest. You have to make sure that the code running on the PC during step 2 is tight enough that the RC isn't sitting there waiting.
The program is written in VB 6.0 with the MSCOMM control as the serial interface. I'll make the source available when I have time to clean it up.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
White Paper Discuss: Using an Operator Interface with the 2004 EDU RC CD47-Bot Extra Discussion 6 20-01-2004 21:11
Some code in C that we may need if we are in trouble Andrew Rudolph Chit-Chat 16 07-10-2003 21:34
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Controlling a FIRST robot with a Lego RCX Controller? archiver 2001 5 24-06-2002 04:19
