Go to Post The closest and strongest friendships that I have formed, however, have come from the FIRST robotics program. Friends that I can call “brother,” that I can call “sister,” that I can just call “family.” - DanDon [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 24-11-2003, 19:19
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Dirt Cheap edu Controller!
Hey guys!
So, I was digging around my sister's closet the other day, when I stumbled upon her sega genesis ( ) and it had both controllers with it. I unplugged a controller and noticed...It was a DB9 Serial connector!
So, I rushed to my PC in search of the Genesis Controller pinouts, and lo-and-behold there they were. It was at this point I realized that the Genesis controller could wire into the eduBot!!!
So, Here's how to do it:
First, find an old serial cable you don't need. Cut off about 3-6" away from the Male connector. Strip out the individual cables.
Here's a Diagram of the DB9 male connector:
1 2 3 4 5
__________
| o o o o o |
\_o_o_o_o_/
6 7 8 9
and this is the Genesis controller:
5 4 3 2 1
__________
| o o o o o |
\_o_o_o_o_/
9 8 7 6
Next, you need 6 3-hole connectors, like those on your switch input. We'll use digital inputs 3-8 for the controller.
Here's What each Digital input will be:
3: UP
4: DOWN
5: LEFT
6: RIGHT
7: BUTTON1
8: BUTTON2
The first connection(dig_in3) will supply the + 5v power to the controller.
So here's the connections:
PIN 3 4 5 6 7 8
SIG 1 2 3 4 6 9
+5V 5 X X X X X
BLK 8 8 8 8 8 8
So, Connect all the BLKs from the 3-slot connectors into pin 8 on the DB9 connector
Plug the +5V pin on Input #3 into pin 5 on the DB9 connector
Plug the SIGs into the pin number listed above for the appropriate button
Now you're ready to roll!
Plug your connectors into the right input pins, and connect your genesis to the male adapter, and you're done!
In your program, make sure pins 3-8 are set for input.
You can set up an 8 way directional pad by checking to see if 2 directional buttons are in: eg up + left = upleft
Anyway, I'm still putting the finishing touches on mine! I'll be sure to post pics when I'm done!!!
(PS:
http://www.gamestop.com/product.asp?product%5Fid=900145
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 24-11-2003, 19:30
IMDWalrus's Avatar
IMDWalrus IMDWalrus is offline
This is a line...
AKA: Paul
FRC #0818 (Genesis '02)
IMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to behold
Send a message via AIM to IMDWalrus
That is seriously cool. Great job.
Next question (when you're finished, of course): how well does it work?
Unread 24-11-2003, 21:18
Sachiel7's Avatar
AKA: Shayne Helms
I just finished it.
It works GREAT!
I guess I get pluspoints for the oldskool factor
Instead of using a bunch of 3 pin terminals, I just took 2 of my old floppy drive cables out of my ol 486 (ah, the days) and used them as a terminal strip of sorts.
One was used for the top 2 rows of pins, and the second for the bottom row. The sizing was uneven on the heads though, so I had to bend down the bottom row of pins for it to fit
But it's ok
If you've got a few bucks, I'd recommend building it.
I'm scanning a pic of it now, I'll post a link in a while.
-=Sachiel7=-
Unread 25-11-2003, 21:16
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Sounds good.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 06-12-2004, 20:39
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Dirt Cheap edu Controller!
Sorry for bumping this thread.. but I wanted to link the sega pic in the gallery to the thread for future ease of searching for this subject..
So.. Yeah..
http://www.chiefdelphi.com/forums/pictures.php?s=&action=single&picid=5818&direction =DESC&sort=date&perrow=5&trows=5&quiet=Verbose
C controller Rorschach Kit & Additional Hardware 1 29-10-2003 19:21
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Visibility of Robot Controller and Reset Button Tracy Rules/Strategy 1 17-02-2003 07:36
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
Possible Configuration to keep things cheap archiver 1999 8 23-06-2002 23:03
