Go to Post If it looks like an appendage, quacks like an appendage and moves like an appendage...it is an appendage... - Bob Steele [more]
Unread 26-11-2003, 00:02
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Worn Shifting Dogs
I have been doing some research on transmissions, and it seems that many teams are using "two speed shift-on-the-fly" transmissions that use a shifting dog to engage one gear ratio or another by locking together with a counterpart. I was originally thinking of a tranny with a similar mechanism, but I was worried that the shifting "on-the-fly" would result in a very violent transition between high and low gear, in addition to excessive wear on the shifting dog, from meshing with it's gear-mounted counterparts. Is there a trick to these transmissions, or do you just have to move the dog really really fast and hope it doesn't grind against the dog gears? If my concernes are justified, then what kind of life expectancy do you get before you have to replace the dogs?
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Shifting Gears MBosompra Technical Discussion 71 23-07-2004 02:49
gear shifting Stephen Kowski Motors 19 30-03-2003 21:33
Junkyard Dogs NeO_Weapon General Forum 6 13-04-2002 22:59
Shifting Gears -- Anton Abaya Technical Discussion 26 22-01-2002 21:49
Visteon to leave teams to the dogs? nwagers Rumor Mill 6 24-10-2001 10:56
