Go to Post If this strategy backfires on any alliance that attempts it, they will have no one to blame but themselves. Be smart - know the risks before proceeding. - Travis Hoffman [more]
Unread 02-12-2003, 10:17
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
"Cheap" Robot parts
not so cheap, But inexpensive .this year were being very frugile in our operation and ive been desinging with thaT in mind. and a part that costs $150 and you need... say 4 of them .Could run your money out quick
so, i guess im asking what parts, or manufactoring methods do others use to cut costs:?:
heres my Saviour...
theyre 4"x4"x5/16", hold 300 Pounds, and cost .84 cents each
(speelcheck isint up yet. Save me Brandon)
Unread 02-12-2003, 10:37
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: "Cheap" Robot parts
heres my Saviour...
Tytus has a great point. A good designer can make complex mechanisms which require many expensive parts, but a better designer can make the same mechanism with easy-to-get or cheap parts.
For instance, we made this "ball drive" last year. We wondered how to fabricate the core for the balls. The outside needed to be relatively hard, but tacky. We decided that urethane would work well for the outside, so we just needed to make a lightweight, hard ball. We looked to buy some, but had no luck. We were actually looking at having a guy CNC lathe some PVC plastic down to 2 hemispheres, but we found an answer: steel gazing globes. We could buy hollow steel balls from a landscaping company. These balls are called "gazing globes" and usually are glass. Some are steel. They were $6 per ball. We were glad to find a cheap, workable solution.
btw, Tytus... you can copy and paste your post in Word to perform a spell check.
Andy B.
Unread 02-12-2003, 12:25
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Yep. I totally Agree. In fact we used those bearings back in '02 to pivot our wheels. We eventually took them off (not because they didn't work) but they helped alot.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 02-12-2003, 12:28
Generator of Entropy
FRC #2973 (The Mad Rockers)
Gotta caution you though - I tried to use the part you have pictured in zone zeal as the pivot for our 2 arms (you'll see them in early pictures of Fluffy but not in the version that made it to nationals). We had flat run out of manufacturing resources and time to make the original bearing and support, so I did a quick redesign to use these off the shelf parts from McMaster Carr. They may take 300 pounds of load, but they have no stiffness or strength in off-axis torque. They actually performed better than I expected - the formed sheet metal managed to stay just close enough to keep the ball bearings from departing - but the lack of stiffness caused problems in the drive system (couldn't keep tension).
My favorite activity during week 1 is to go to home depot and stare at stuff for ideas, and to see what I could cluge together for a mechanism. Parts that already have integral hinges or bearings can save you a bunch of time and money. At worst you get a quick prototype; at best you get a functioning component.
Unread 02-12-2003, 21:35
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
An alternative to ball bearings: Just use bronze bushing.
Before assembly, be careful to make sure the mating interface to the bushing is very clean to avoid friction. And of course add some oil.
Raul
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 03-12-2003, 14:29
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
The best way to keep things cheap is to keep them simple. Don't let your design get out of hand. If you catch yourself adding parts here and there just to try and make a design work then maybe it's not a good design. I guess what I'm saying is don't try and design a hand when a claw will work.
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 03-12-2003, 15:11
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Actually bronze bushings should be all ready lubricatd. They cotain little pores of oil that come out when the shaft moves fast enough.
Unread 05-12-2003, 16:02
AKA: Ty
Raul
if you have a shaft runing fast enough the juberactioj is gonna disapper prety fast with that little setup
but i guess its good for slower-moving parts
Unread 05-12-2003, 17:24
Adam Y.'s Avatar
Adam Y.
no team (?????)
Errr I hope you mean lubercation. Anyway oil impregnated bushings do not have that problem since the oil is all ready in the bushing. (Note: I do not know if impregnated is the right word)
Unread 05-12-2003, 17:34
AKA: Ty
OMG! wheens spell check coming back and the orange?
Please everyone out there Dont give me anymore negative rep points for my spelling, i know im working on it
Unread 05-12-2003, 21:49
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Are either of you sure what you mean? (i.e. lubrication )
And yes, impregnated is the right word.
Unread 06-12-2003, 09:18
Guys...
When an oil impregnated bearing (otherwise known as a bronze bushing) gets hot, then the oil starts to exit from the bearing. This hottness could be caused from an overloaded bearing (very high rpm and load) or something next to it getting very hot.
Andy B.
Unread 06-12-2003, 10:48
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
My advice on cheap parts is to remember that you don't have to order from MSC McMaster and 80/20. We were stuck in that track last year, wondering how we could lost weight and cost. For those 5 ft long wings you might have noticed we used some cheap conduit (sp? sorry, I don't have time to run Word). My advice is to take a trip to Lowes or something like that when you need ideas for parts. You can use so many different materials that they have there and they tend to be cheaper than ordering from these other companies.
P.S. If you get your stuff locally that also means that you can run out and get an extra one when you need it the day before shipping!
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 06-12-2003, 18:47
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
There are always alternative ways to do things. Sometimes, the less expensive solution will be adequate, sometimes it won't.
I advocate looking at multiple ways for doing things, and pick the least expensive that does the job.
In the drive system, throw money at it. Bearings, good gears, high quality fabrication. Because, if it doesn't work, the consequences are enormous. And you just don't know in advance how much abuse the thing will have to withstand.
On other systems, you might be able to get away with bushings instead of bearings (or at least cheap bearings), lighter weight materials instead of steel, OTS Home Depot/Lowe's type parts.
I'll give away one "secret" for free for the coming year. Rules permitting, we plan to use hexagonal shafting on all rotational drive parts. After the failed or nearly failed key ways in so many of our shafts last year, we're not taking chances.
Unread 06-12-2003, 20:55
Adam Y.'s Avatar
Adam Y.
no team (?????)
Originally Posted by Andy Baker
Guys...
Andy B.
Is that good or bad? Should the lubrication stay inside it or outside it?
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
