Go to Post Dont give up, because that is when you lose what you have. FIRST is the best experience that I have had throughout my entire life and there is no way ANYONE can make me quit FIRST. - Arefin Bari [more]
Unread 03-12-2003, 14:28
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: 2D/3D Gear Design
I, too, have been unsuccessful in finding a macro or free plug-in to create any gear you need.
What I've found to work best barring that is to search SDP-SI (www.sdp-si.com) for the gear I need (if it's standard) and use their models. The models they have available for download often include one or two modeled teeth which you can then revolve around the gear and make a complete model.
Also, remember that unless you're doing this for rendering purposes, it's a lot less taxing on your hardware to model gears without teeth and makes mating them much easier.
--Madison--
...down at the Ozdust!
Unread 03-12-2003, 14:32
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
Something else you can do is with a little know how, find a drawing like what is mentioned above and then tweak it with Inventor. You can create a spread sheet that you can link with your drawing. Then all you have to do to change the size of the gear would be to change a few numbers in the spread sheet and hit update and you will have unlimited number of gears for that design.
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 03-12-2003, 14:42
Madison's Avatar
FRC #0488 (Xbot)
Ed Sparks' FIRST CAD Library site (www.firstcadlibrary.com) featured/s iParts for Inventor. The sprocket and gear never worked well for me, though. The geometry of gears is a little messy at times.
--Madison--
gearing design calculation question caffel Motors 4 24-03-2003 17:34
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
