Go to Post You can never take enough precautions when it comes to safety. Please, be prepared for anything. - Tom Bottiglieri [more]
Unread 04-12-2003, 07:41
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Re: 2D/3D Gear Design
People please.. read the original post and replys by the original poster.
I Do Not Have Inventor.
I am looking for information on bevel gears.
I almost struck gold with what M said, but the drawings for bevel gears didn't include teeth on SPD-SI. However, those may be able to work for 2D Drawings. Clark, I have GearGen, but that works for Spur gears, which doesn't reeeeaaaaaly help me because while a bevel gear begins as a flared spur of sorts, i don't know the point where the tooth stops and begins because I'm only being given the Pitch circle.
Unread 11-12-2003, 13:26
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
Would it be possible to take all of the information that you have, create a spur gear like 2D drawing, and extrude it using an appropriate taper angle?
indieFan
Unread 17-12-2003, 13:20
Gadget470's Avatar
A Fire Outside
Possibly, but I honestly don't know, see the gears have an odd shape, they are not actually conical from top to bottom. More like:
  /'__________'\
 ¹---..    ..---¹   (Cut-away profile)
      |____|
  /'__________'\
 /____      ____\  (would work w/ Taper Angle)
      |____|
Edit:
Better yet:
Unread 17-12-2003, 15:25
FRC #5941
In looking at the bevel gear, what if the gear is created as if it were a simple taper angle. Then, for the outer angle, drawing a hollow cylinder with the appropriate taper on the inside and use subtract. For the inner angle, it would be a solid cylinder with the proper external taper and subtract that.
indieFan
gearing design calculation question caffel Motors 4 24-03-2003 17:34
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
